peter 25112 Apr 2021 15:34Hello, is it possible to seal floor-to-ceiling windows on the inside at the lower section (between the base plate and the window) with EPDM foil to make them windproof?
I planned to use EPDM for sealing because I have brackets at the bottom and want to coat the foil with bitumen afterward.
Is there anything that would speak against this?
peter 2511 schrieb:
Hello, is it possible to seal floor-to-ceiling windows on the inside at the lower section (between the base plate and the window) with EPDM membrane to make them airtight?
I intended to seal them with EPDM because I have brackets at the bottom and plan to finally coat the membrane with bitumen.
What would argue against this? It is usually sufficient to install an EPDM tape on the outside.
peter 25112 Apr 2021 15:55SchwalbenFahre schrieb:
It is sufficient if the EPDM tape is applied on the outside.I wanted to apply it inside at the floor area to make it airtight against drafts.peter 2511 schrieb:
I wanted to stick it on the inside at the floor area to make it windproofWhy do you insist on doing it from the inside?Is it no longer possible on the outside?
peter 25112 Apr 2021 19:07rick2018 schrieb:
With floor-to-ceiling windows, the frame is below the floor level.
The glass reaches down to the floor. This is probably more about floor-to-ceiling frames...No, the floor-to-ceiling windows are on the first floor.Similar topics
