ᐅ Flush-mounted SAT socket: Modem not working. Frequency filter?
Created on: 6 Jun 2016 08:39
bluminger
bluminger6 Jun 2016 08:39
Hello.
We have purchased a flush-mounted satellite socket[1]. The coaxial cable comes up from the basement to the next floor and then connects to this socket, where the cable modem is plugged in from the outside.
If we manually connect the cable from the basement directly to the modem cable, it works. However, it does not work when going through the socket. We tested two sockets, and neither worked.
Is it possible that there is a frequency filter inside that only allows TV frequencies to pass, but not the spectrum needed for the cable modem?
If so, what kind of socket would we need?
Thank you very much!
Metal lamp holder with cable connection and mounting tabs.
8
86bibo
6 Jun 2016 08:59
First: Are you sure that you plugged the cable into the correct connector?
Second: The cable network is a very large-scale network (your neighbors are connected to it as well) and therefore must be properly configured so that everyone receives sufficient signal strength. For this purpose, there are attenuators in the cable outlets (both for the connection and for distribution). These can be calculated, but you must not simply add any outlet in between. If the neighbor no longer receives a signal because you installed an additional outlet, there will be trouble. Most cable providers also prohibit installing outlets yourself. Get a professional involved; otherwise, it probably won’t work.
bluminger6 Jun 2016 09:30
It is a single-family house, so there are basically no neighbors who could be disturbed.
In my opinion, we have already used the proper connection – there really isn’t much room for error… or is there?
nordanney
6 Jun 2016 09:54
Who configured the cable connection for you? Normally, the cable network operator comes out to do that.
Looking at our connection, I would have my doubts about how a layperson could correctly connect the right cable to the proper port – there are so many options to choose from.
bluminger6 Jun 2016 10:06
The modem was previously located in the basement. We simply replaced the cable that used to connect to the modem in the basement with a 12-meter (39 feet) long cable and routed it one floor up.
This way, the modem still works on the upper floor. However, since it doesn’t look very neat when the cable just comes out of the wall, it should be properly installed through a socket. The correct signal will definitely enter the socket, but it won’t come out again.
miho
6 Jun 2016 11:26
That really sounds like an inappropriate frequency filter inside the box, but you should take the advice above seriously. Neighbors in nearby houses on the street could also be affected. Why does the modem have to go upstairs? Can’t you distribute the network instead?
