ᐅ Roller shutter box (also known as roller shutter housing or casing) is the enclosure that contains the rolled-up shutter curtain above a window or door. It protects the shutter mechanism from weather and dust while allowing the shutter to be operated smoothly. Proper insulation of the roller shutter box is important to prevent thermal bridging and improve the overall energy efficiency of the building. Installation requirements and dimensions may vary depending on local building codes and the type of wall construction.
Created on: 14 Jun 2016 11:57
lavendel
lavendel14 Jun 2016 11:57
what are the advantages and disadvantages of an exterior inspection cover for roller shutters? And is this type now commonly installed?
I only know about the interior ones (that’s what we currently have).
Looking forward to your answers!
Neige14 Jun 2016 12:16
a major advantage I see with exterior roller shutters is that they prevent thermal bridging above the window. In addition, any repair work is easier to perform without causing damage inside the room.
andimann14 Jun 2016 12:40
Hi,
In addition, any repair work is easier and can be done without damaging the interior of the room.
And that can be both a blessing and a curse. If a roller shutter is broken, you can only access it from the outside. This can sometimes be inconvenient, especially on the upper floor or the Xth story...
Andreas
Mycraft14 Jun 2016 13:41
And in winter, it gets especially interesting...
lavendel14 Jun 2016 14:17
Thank you for your answers 🙂 Our (prospective) developer installs the external ones. But it’s really a matter of personal preference. ....? Is there a price difference between the two? Best regards
Sebastian79
14 Jun 2016 14:58
Neige schrieb:
Additionally, any potential repair work is easier and can be done without damaging the interior of the room.
I have an access panel made of white plastic under the box – this way, nothing needs to be unscrewed or damaged. 😉
