ᐅ Installing and Adjusting Soft-Close Doors and Drawers on Ikea Metod Kitchen Cabinets After Installation
Created on: 2 Nov 2017 20:38
Godwin
Godwin
2 Nov 2017 20:38
Some time ago, I purchased an Ikea Metod kitchen without soft-close doors and drawers. Now I would like to retrofit the soft-close function for doors and drawers to improve usability and avoid unnecessary wear. My questions to the community are:
- Which soft-close mechanisms actually fit Ikea Metod cabinets without requiring major modifications?
- Is it possible to install soft-close dampers afterward on doors and drawers that were not originally equipped with them?
- What tips are there for correctly adjusting the soft-close dampers so that doors and drawers neither slam shut nor close too slowly?
- Are there any special considerations during installation to ensure the function remains trouble-free in the long term?
I would be very grateful for experience reports, instructions, or recommendations. It would be helpful if concrete suggestions for suitable products, tools, and adjustment techniques could be provided.
Godwin
nedagla
3 Nov 2017 09:12
Godwin schrieb:
Now I want to retrofit soft-close functionality for doors and drawers to improve the user experience and prevent unnecessary wear.
Absolutely great that you want to upgrade! It really makes a HUGE difference in everyday use 😊
I retrofitted the soft-close dampers myself in my Metod kitchen – it’s actually quite straightforward:
- For doors, you can use the dampers from Ikea directly; they are specially designed for Metod and fit perfectly. Installation is simple, the dampers are screwed to the side of the cabinet carcass, and often there are pre-drilled holes.
- For drawers, you need to pay a bit more attention since the drawer slides are crucial. Ikea uses different sliding systems, for example Metod with full extension. I clicked the soft-close modules directly into the slides – that works really well.
- It’s important to adjust the dampers properly: not too weak, or the doors will still slam, not too strong, or they will close too slowly. Usually, you can adjust this with a small lever.
My tip: just go step by step, start with one door or drawer, test it, then continue. And don’t be afraid of screwdriver and drill – it’s definitely doable!
Good luck, you’ll manage it for sure! 💪
PIDAN
3 Nov 2017 14:29
nedagla schrieb:
Drawers require a bit more attention, as the drawer slide is crucial.
That is correct. Soft-close dampers only work with slides that support this feature. Ikea mainly uses full-extension slides with integrated soft-close modules for Metod cabinets.
For retrofitting, the following points should be considered:
- Check compatibility: For older drawer slides without soft-close, it is often more practical to replace the slides rather than install individual dampers afterwards.
- The soft-close mechanism is usually installed beside or behind the slide rail.
- The dampers are generally available from Ikea as replacement parts (part number: 108574). Alternatively, compatible aftermarket modules exist.
- For doors, there are side-mounted dampers attached to the inside of the cabinet. Make sure the doors are properly aligned before installing the dampers.
Adjustment is usually made via a screw or a small adjustment lever on the damper — this affects the closing behavior.
Tools: Phillips screwdriver, possibly a cordless drill, spirit level for door alignment.
Conclusion: Retrofitting is possible, but for older Metod models, replacing individual parts may be more cost-effective than attempting a retrofit. The decision depends on the condition and age of the existing kitchen.
Rosan
4 Nov 2017 08:47
Retrofit soft-close installation works well if the drawer slides allow it.
For doors:
- Attach soft-close dampers on the side with screws.
- Screw holes are usually already present.
For drawers:
- If full-extension slides lack soft-close, it’s better to get completely new slides.
- Dampers can usually be integrated as modules.
Adjustment is possible with a screw or lever.
Make sure doors and drawers are properly aligned beforehand!
