ᐅ Removing KALLAX baseboard – how to do it?
Created on: 21 Jun 2024 19:43
tadeuszga2
I have a question regarding the removal of the baseboard on an IKEA KALLAX shelf unit. Specifically, I want to take off the baseboard because I need to move the shelf along a wall with an adjacent baseboard, and the baseboard gets in the way, especially when relocating it onto new flooring. However, I am unsure how the baseboard is attached and how to remove it without damaging either the shelf or the baseboard itself.
Has anyone had experience with how to best remove the KALLAX baseboard? Which tools are useful, and what should I pay close attention to? Thanks in advance for any advice!
klo61
22 Jun 2024 09:45
Hello!
For removing the KALLAX baseboard, I recommend the following: The baseboard is usually clipped in with small retention tabs, so work carefully. Ideally, use a flat spatula or a plastic wedge to pry it off – metal tools can easily damage the wood.
If the baseboard is very tight, you can gently warm it in certain spots (for example, with a hairdryer) to soften the wood a bit. Then loosen the baseboard in several steps with prying movements. Do it piece by piece, otherwise the baseboard tends to break at the clip points.
Important: After removal, lightly deburr the contact points with fine sandpaper so that nothing gets stuck or jumps when reinstalling.
Good luck, and don’t worry— with a bit of patience, it usually works well! 🙂
Davidleo
22 Jun 2024 11:27
Wow, great thread! Thanks for all the excellent tips so far!
I had exactly the same problem when I rearranged my KALLAX shelf! Just carefully use a thin putty knife, wiggle it a bit, and the baseboard comes off! The skirting board still looks great afterwards because nothing breaks if you are careful.
The best part: you can easily click it back in place afterwards if you want. I did that right after I laid new laminate flooring. So go for it! It’s much easier than you think. Enjoy your DIY project 🙂
Surela
22 Jun 2024 12:56
GALEO4 schrieb:
The baseboard basically serves only an aesthetic purpose and keeps the shelf slightly elevated.
That is generally true, but to not overlook the details: The baseboard prevents the shelf from sitting directly on the floor, which cushions against moisture or unevenness and thus helps to extend the furniture’s lifespan. Additionally, the edges close off cleanly, keeping dust and crumbs away from the shelf base.
Davidleo schrieb:
The baseboard still looks great afterward since nothing breaks if you’re careful.
That’s exactly why patience and a methodical approach pay off. Is there a specific surface on your shelf you need to watch out for, or is it the standard model?
tadeuszga2
22 Jun 2024 14:02
Surela schrieb:
Is there a specific surface on your shelving unit that you need to watch out for, or is it just the standard model?
I have the typical white KALLAX with a melamine finish, so no special surface. I haven’t had any scratches so far and want to keep it that way. Thanks for the tip about moisture buffers and clean edges—I hadn’t thought about that. I’ll be careful with it, probably using a putty knife and some patience.
If anyone has advice on the best way to reinstall the baseboard at the end, feel free to share!
