ᐅ Incentives for Electric Mobility in New Construction
Created on: 30 Sep 2020 20:14
C.beckmann1986
since I am not an expert in this field and want to avoid making mistakes, I would like to know your opinion.
We have purchased a newly built house from a developer, and currently the electrician is working on the property. A high-voltage connection is planned for the garage. However, an electric or hybrid car is not planned within the next 1-2 years. Does it make sense to have a wall box installed right away because of the current incentives? At least that is what the electrician suggested.
Or is just running the cable enough for now (is there any funding for that)? How would you proceed?
Thanks for your advice.
rick20181 Oct 2020 08:52
An 11kW wallbox is sufficient. 22kW is more than necessary. The standard connector for all electric cars is Type 2.
Fast chargers use different connectors (mostly CHAdeMO) but are DC, so they are generally not relevant for private use.
There are also wallboxes without an attached cable but with a socket instead. This allows you to use different cables.
However, you can charge at any wallbox.
nordanney
1 Oct 2020 08:53
Pinky0301 schrieb:
Is there a universal wallbox that fits all electric cars?
There are no wallboxes designed specifically for individual car models. An 11kW box with or without a fixed cable is sufficient. It also generally doesn’t require a building permit / planning permission.
nordanney
1 Oct 2020 08:55
P.S. I will order an Eve Single Pro-line with 11kW (11.7 hp), as my employer can bill the electricity I use to charge my company vehicle through it.
OWLer1 Oct 2020 09:07
netuser schrieb:
by the end of November
Oh, I need to do some more research on that. We had actually planned for it. But by the end of November, at best, we will only have signed the contract for the system. Completion will be no earlier than May 2021...
Oh dear
Bookstar
1 Oct 2020 10:38
would always z
rick2018 schrieb:
An 11 kW wallbox is sufficient. 22 kW if you want to go above and beyond. The standard connector is Type 2 for all electric vehicles.
Fast chargers use different plugs (mostly CHAdeMO), but these are DC and generally not relevant for private use.
There are also wallboxes without an attached cable but with a socket instead. That way, you can use different cables as needed.
I agree with you, but if possible, always install 22 kW. It costs almost the same, and you have double the charging speed if needed. Batteries keep getting bigger, and future vehicles in the premium segment will likely all include 22 kW chargers as an option.
If you only plan to charge overnight, then an 11 kW charger will probably be sufficient in many cases.
opalau1 Oct 2020 11:43
Our utility company requires a 22kW OCCP, as I have learned, in order to reduce the charging power if necessary. However, I still tend to go with 22kW right away to have this issue settled for the future.
