ᐅ Process issue with the Ikea Atlant trap
Created on: 29 Sep 2012 14:33
AndyHH_6537
AndyHH_6537
29 Sep 2012 14:33
my first post here and also my first problem.
Our new Faktum kitchen in Abstract Red looks great. However, I have an issue with the water drainage in the Atlant sink.
From my amateur perspective, I believe I installed everything correctly, but the water drains from the sink very, very slowly. When the dishwasher pumps out, water even gets pushed back into the sink.
The strange thing is, when I remove the drain hose from the wall drain pipe and hold it into a bucket, the water flows perfectly. Even if I insert the drain hose just one centimeter (0.4 inch) into the wall drain, it drains, but water also leaks beside it.
Does anyone have any ideas? – I’m not happy with it this way!
IKEA-Experte
30 Sep 2012 13:13
From the picture, it seems to be correct. I would just try to turn the trap to the back right and then guide the hose "straight" into the drain pipe. As far as I can see, this would create more space in the cabinet and the hose would enter the drain pipe at a steeper angle. Otherwise, it sounds like the plumbing installation might not be in proper condition. Was it better before?
AndyHH_6537
30 Sep 2012 18:10
From the picture, it looks correct. I would just try to rotate the trap towards the back right and then guide the hose “straight” into the drain pipe. As far as I can see, this would create more space inside the cabinet and the hose would enter the drain pipe at a steeper angle. Otherwise, it sounds like the home's plumbing might not be in proper order. Was it better before?
I’m starting to suspect the problem is with the drain pipe. Lately, the washing machine has also been draining water into the kitchen sink in the other room, which isn’t connected to that trap.
With the old sink, everything worked perfectly fine, but that might just be a coincidence.
