Hello, I’m Christina (new to the forum)!
We are currently building a house and, once the project is completed, are considering adding a pool in the garden. What are your experiences? Can it be done as a DIY project? What type of heating have you chosen? How did it go for you?
Thanks in advance and best regards,
Christina
Christina
DerMitDemFH21 Aug 2022 22:39rick2018 schrieb:
Do not change anything about the supply and drainage lines. Water, electricity, and wastewater connections still need to be installed. A hole is also required…We will also have a pool. The pool installer said that a wastewater connection is not necessary. Just pump the water out.
For electricity, you should install at least two runs of 3x2.5 mm² (3x0.01 in²) cables for heating and equipment.
And where does the backwash water go? Emergency overflow?…
I think you’ve got yourself a so-called “specialist” there.
No decent pool builder would make such a statement. Sorry if I’m being so direct.
3x2.5 is also a joke. Depending on the heat pump, counter-current system, lighting, and cover, that won’t be sufficient either.
