ᐅ Ergonomic Planning and Efficient Use of an Ikea Metod Kitchen Unit in a Small Space
Created on: 2 Nov 2023 08:37
Anastasi59
Anastasi59
2 Nov 2023 08:37
I am currently planning to design my kitchen using an Ikea Metod kitchen unit in a very tight space. I want to focus especially on ergonomic planning to ensure as comfortable a workflow as possible despite the limited area. I am interested in solutions for the optimal arrangement of elements, suitable worktop heights, and how to make storage space as efficient as possible.
I am aware that the standard dimensions of Ikea Metod cabinets play a role, but how can these be combined in a small space to keep walking distances short while ensuring everything is ergonomically reachable?
Does anyone have recommendations on how to best plan a small kitchen unit with Metod for everyday use? For example, regarding countertop height, the placement of the sink and stove, or space for waste sorting? I would appreciate practical tips, as well as advice on the planning process with Ikea’s measurement system—such as important aspects to consider to make sure everything fits well and the usage does not cause back or knee pain despite the minimal space.
Thank you in advance for your experiences and advice!
BOLUKEO
2 Nov 2023 09:50
Hi Anastasi59,
- You should adjust the working height to your body size; about elbow height minus 10cm (4 inches) is a good guideline.
- Plan the sink and stove preferably in a straight line and not in a corner, as this makes working easier.
- Use tall base cabinets with pull-out internal drawers for storage.
- For waste sorting, it is best to have it in an easily accessible base cabinet under the countertop.
These are the basics for ergonomic planning in a small space.
Gafiel
3 Nov 2023 17:23
Hello Anastasi59,
I would like to go into more detail, as the topic of ergonomic kitchen planning in a compact space is quite complex. It is important to first measure your own height accurately, as this determines the ideal working height of the countertop. For most people, the optimal height is approximately at elbow level minus about 5-10cm (2-4 inches) to allow comfortable chopping and handling.
BOLUKEO schrieb:
- You should adapt the working height to your height; roughly elbow height minus 10cm (4 inches) is a good guideline.
Basically, it is advisable to choose multifunctional elements when working with limited space. For example, with Ikea Metod, you can optimally combine tall cabinets with pull-out drawers for pantry items and dishes, so you don’t have to constantly bend or stretch. You minimize walking distances by arranging the stove, sink, and refrigerator in an efficient triangle— a classic kitchen design rule.
BOLUKEO schrieb:
- Plan the sink and stove preferably in a line and not in a corner, as this makes working easier.
The space under the countertop should definitely be used: waste sorting is ideally placed under the sink, but with Ikea Metod, special pull-out systems like the VARIERA bin are also suitable for separating waste and recycling effectively. Additionally, you can equip corner cabinets with carousel systems to unlock dead corners and create maximum storage space on a small footprint.
Besides pure ergonomics, it makes sense to keep the working surface as clear as possible and place only the most frequently used items within easy reach. The rest can be organized in wall cabinets or drawers.
One more tip: it’s best to use the Ikea kitchen planning software to record all measurements precisely, including the height of the plinth and plinth boards. This helps avoid surprises during installation.
I hope this helps—feel free to ask if you want more specific tips, especially if you can share measurements or a floor plan (without photos).
Jeanbar
4 Nov 2023 11:02
Hello Anastasi59,
your question addresses a central aspect that many often underestimate when planning a kitchen: ergonomics in a small space requires careful planning and prioritization, especially with the Metod system, which, although modular, has fairly fixed dimensions.
I would like to share some basic points that might help you:
- Worktop height: As already mentioned, having a work height adapted to your body size is essential not only for comfort but also to prevent back pain.
- Layout of the kitchen run: It is usually recommended to place the sink in the middle (or at least close to the water connection), the stove as close as possible to it, and the refrigerator not too far away. This reduces unnecessary steps.
- Storage design: Use drawers instead of doors, as they provide better access and overview—this is especially important in small spaces.
- Waste sorting can be implemented within a 40cm (15.7 inch) base cabinet solution, which saves a lot of space but remains practical.
- Corner solutions (for example, with rotating carousels) should generally be avoided in a very small run unless you can really make optimal use of the functionality.
Gafiel schrieb:
Besides pure ergonomics, it makes sense to keep the worktop as clear as possible and place only the most frequently needed items within easy reach.
This is a very important point! Especially in tight spaces, clarity is crucial—avoid "clutter" and ensure clear organization.
If you have specific dimensions or a rough plan, I’d be happy to take another look tailored to your situation.
