ᐅ Hardwood Flooring or Tiles with Cats – Are There Valid Concerns?
Created on: 1 Aug 2016 14:38
Gatho
we are currently building a semi-detached house with underfloor heating and are still unsure about the flooring for the ground floor. The entrance area and guest toilet will have floor tiles.
So far, the plan was to install oiled hardwood flooring in the living area including the kitchen. However, since we have two cats who sometimes vomit, we are worried this might be harmful to the hardwood floor.
The alternative would be wood-look tiles. We currently live in a rental with plain white tiles, so wood-look tiles would be the only compromise. However, we would really like to enjoy the indoor climate that hardwood provides, but we have the concerns mentioned above.
What are your experiences in this regard?
Best regards and thanks!
Gatho
Ground floor layout: kitchen, hallway, guest toilet, dining, living, terrace, garage and storage room.
toxicmolotof
1 Aug 2016 22:29
We have no issues with porcelain tiles. The critical point here, however, is if the grout is attacked by mold. So, it's important not to leave it sitting for too long and to wipe it as soon as possible. But this probably applies in general.
If by tiles you mean marble or similar materials, then... not a good idea!
Bieber0815
1 Aug 2016 22:41
That was my thought as well: This isn’t a problem specific to parquet flooring; spilled liquids shouldn’t be left on tiles or any natural stone either. Cheap laminate is very sensitive. Options now include linoleum, vinyl flooring, or high-quality sealants…
As is often the case: one end is “somewhat attractive,” but requires intensive care and is sensitive, while the other end is very practical, durable, and resistant, but usually less homely or cozy.
Saruss
6 Aug 2016 15:36
Neige schrieb:
Before considering which type of flooring to choose, it might be helpful to understand why the cats are vomiting. In most cases, it is caused by a worm infestation.
So, possibly a deworming treatment is needed.
Regarding wooden flooring:
If the wood is properly oiled and finished with an oil-based seal that makes the floor more resistant, and stains are removed promptly, it should definitely be manageable. Oiled hardwood flooring has the advantage over lacquered hardwood that it can be repaired relatively easily.
Depending on the type of cat, you might need to worry if they don’t vomit. Normally, cats do this to clear hair from their digestive system that would otherwise cause intestinal blockage.
from on the go
Neige6 Aug 2016 15:40
As far as I know, since we also have a house cat. I should have been clearer about why cats vomit, when, and with what intensity.
Gatho
6 Aug 2016 15:48
Next week, we will receive a quote from a professional company for oiled oak parquet, white oiled.
We plan to lay parquet throughout the entire ground floor, including the kitchen (except for the entrance area and guest bathroom, which will be tiled). We both really like wood, and since we have chosen the oiled version, stains can be removed quite easily.
Neige6 Aug 2016 16:03
Please note that white oiled with pigment means it is somewhat more delicate and requires more effort to maintain and "repair."
