ᐅ Parquet Flooring on Underfloor Heating – Is Thermal Resistance a Concern?
Created on: 24 Feb 2018 21:17
blaupuma
We are planning to have oak parquet flooring installed. Today, at the specialist store, we were advised to have the flooring glued down. This supposedly eliminates the need for insulation and is better for underfloor heating. In general, parquet is not ideal for underfloor heating (the heat does not transfer as well as with other floor coverings).
Has anyone had extended experience with this? What should be considered?
By the way, the installation is supposed to cost 30 euros per square meter (about 3.3 square feet) [emoji15]—15 euros for the installation and 15 euros for the adhesive.
Thank you very much for your input.
Arifas25 Feb 2018 09:31
I don’t understand the calculation. Surely, you wouldn’t pay 30 euros just for the adhesive. The 30 euros includes the labor costs.
truce25 Feb 2018 09:41
It says 15€ for the adhesive and 15€ for labor. How do you end up with 30€ just for the adhesive?
For comparison:
We pay 22€ for installation including adhesive.
But that was also renegotiated.
By the way, online you can find adhesive (PCI or Wakol) for about 5-6€/sqm (square meter).
aero2016
25 Feb 2018 09:44
It is true that hardwood flooring takes longer to warm up compared to tiles. However, it also retains heat for a longer period – so theoretically, you could lower the heating earlier than with tiles because the hardwood does not cool down as quickly.
Have you asked the flooring installer about solid hardwood? It often isn’t more expensive.
25 Feb 2018 10:15
aero2016 schrieb:
It is true that parquet flooring takes longer to warm up compared to tiles. However, it also retains heat longer – so theoretically, you could lower the heating earlier than with tiles because parquet doesn’t cool down as quickly.
Have you asked a parquet installer about solid wood parquet? It’s often not more expensive.
That is not entirely correct. Wood, including parquet, is a poor heat conductor and also a poor heat store. If you lower the heating, the surface will cool down faster than stone. The best heat conductors are tiles. They also retain heat longer, as seen with soapstone stoves.
Whether parquet is suitable for underfloor heating depends on the specific product. The installation method (such as gluing) is also specified in the product details.
Lumpi_LE
25 Feb 2018 10:15
In all physical and heating-related matters, a completely incorrect statement @aero2016 ...
Basically, it is not a problem, but slightly higher supply temperatures are required, which leads to increased consumption. However, this should not be a major concern.
Knallkörper
25 Feb 2018 10:20
Lumpi_LE schrieb:
was zu einem höheren Verbrauch führt.
Not necessarily. It depends on the heating system. With an air-to-water heat pump, you are, of course, correct.
