ᐅ Care and Maintenance of Laminate Countertops & Dishwasher vs. Kickboard/Baseboard
Created on: 9 Sep 2011 11:26
msiegberg
msiegberg
9 Sep 2011 11:26
Dear Ikea fans,
Once again, I need to rely on your experience with two or three questions 🙂
The Numerär countertop is already factory-oiled and should be regularly re-oiled. Before oiling, sanding is of course very important. Which sandpaper grit should be considered? Are there any experiences? I would opt for a very fine grit (240) since I don’t need to remove much material.
The next question is probably a classic. We are using the DWTI 60 dishwasher with a full integrated panel. After installing the toe kick, the dishwasher no longer opens fully and collides with the toe kick. The only solution seems to be sanding or cutting back the toe kick a bit—am I missing other options?
Best regards, Micha
IKEA-Experte
9 Sep 2011 18:28
Cutting out the base in that spot is the only solution.
Sanding the countertop is only necessary if you want to remove stains and such, but not with every re-oiling.
bergpriv
10 Sep 2011 12:00
I additionally sealed the cut surface with varnish since there is always some moisture involved!!!!
bergpriv
