ᐅ After moving, my KALLAX unit has dents on its surface – is it possible to conceal them?
Created on: 20 Dec 2023 19:27
REOAN3
REOAN3
20 Dec 2023 19:27
I recently moved my IKEA KALLAX shelf, and during the process, some unsightly dents and minor indentations appeared on the surface. The surface is coated with a thin plastic layer, so I’m not sure if the damage can be repaired or concealed without having to buy a new unit or repaint it.
Are there any proven methods to visually reduce or remove these dents? I’ve thought about using wood repair markers, but I’m uncertain since the material isn’t real wood. Maybe special paints or fillers could work?
Has anyone had experience with treating small damages on KALLAX units in everyday situations? I would appreciate concrete tips or advice on what should be avoided.
Thanks in advance!
Filippo
20 Dec 2023 22:13
Hello REOAN3,
regarding your issue with dents on the surface of a KALLAX shelf, I can share some insights from my own experience and research. First of all: KALLAX fronts are typically made from MDF or particleboard and covered with a melamine-coated plastic foil, which makes scratches and dents difficult to repair.
REOAN3 schrieb:
The surface is rather coated or covered with a thin plastic layer, so I’m not sure if the damage can be repaired or concealed without buying a new unit or repainting.
This coating is durable but not flexible, so dents often become permanent. Small, shallow dents that only slightly compress the coating can sometimes be treated with heat—for example, by gently warming with a hairdryer and then lightly moistening to allow the MDF to swell and slightly “lift” the dent.
However, caution is needed to avoid damaging the plastic or causing bubbles.
REOAN3 schrieb:
I’ve considered wood repair markers but I’m unsure because the material is not real wood.
Wood repair markers can help match color or tone but do little for indentations or dents. For small blemishes, I recommend melamine repair kits available at hardware stores. These contain fillers and color tones specially designed for furniture with plastic surfaces.
If you don’t mind customizing the shelf a bit, you could also use matte furniture stickers or thin films applied over the damaged area. This visually conceals the damage well and avoids more complex repairs.
I’m curious about the size and depth of the dents. Are they on the front panel or more on the side? Depending on location and severity, the approach may vary.
I hope this gives you some initial ideas. If you want to try, avoid aggressive abrasives since the surface can quickly become rough or dull.
GOLO42
21 Dec 2023 08:44
Good morning REOAN3,
I would like to add to Filippo’s comments because the topic is actually more complex than it might seem at first.
It is especially important to carefully inspect the cabinet of the KALLAX. Often, these are not just superficial dents, but occur due to localized pressure on the MDF or particleboard panels, leading to permanent indentations. The melamine resin-coated surface is not really repairable in the traditional sense (e.g., like solid wood).
Filippo schrieb:
The KALLAX fronts are typically made of MDF or particleboard and covered with a melamine-coated plastic foil, which makes scratches and dents difficult to repair.
In my opinion, the best option would be a targeted color or surface touch-up. There are special furniture repair kits designed specifically for plastic-coated furniture parts. These include fillers, color paste, and clear lacquer in small quantities. The process would look like this:
1. Clean the damaged area with a neutral cleaning agent
2. Lightly sand with fine sandpaper (grit 800+) – if the dent is deep enough for filler
3. Apply a suitable filler in multiple thin layers
4. After drying, gently smooth the surface
5. Color match using furniture markers or a fine paint roller
6. Apply a final protective clear coat
REOAN3 schrieb:
Or maybe special paints or fillers could be used?
That is definitely possible but requires precision and a careful touch. For small dents, filling with white or beige epoxy resin can also work, which can then be shaped and sanded.
This method is practical only if the damage is concentrated in small areas. Otherwise, replacing the front panel (or covering it with high-quality furniture film/veneer) is often more sensible.
How large are the damaged areas? For larger damage, I would advise against “cosmetic” repairs. Also, what color is the KALLAX – white, black, birch? That affects the choice of repair materials.
I look forward to your feedback!
barle
21 Dec 2023 10:56
a brief overview of the options:
- Dents in melamine-coated furniture can rarely be completely removed.
- Small scratches can be repaired with repair wax or a furniture touch-up pen.
- For larger dents, often only laminate overlays or new fronts help.
- Heat (e.g., a hairdryer) usually does not work on coatings.
If it’s just about appearance, use repair wax in a matching color and apply it carefully.
Regards
sifope
22 Dec 2023 13:34
Filippo schrieb:
KALLAX fronts [...] covered with a melamine-coated plastic foil
This is exactly the point I want to question: The melamine-coated surface has a completely different material behavior compared to real wood or even painted wood. That’s why many conventional repair methods are technically not ideal – and can even make the problem worse.
I am skeptical about Filippo’s idea of heat treatment. Melamine films are sensitive to heat and can discolor or form bubbles.
GOLO42 schrieb:
The best option would be [...] furniture repair kits specifically designed for plastic-coated furniture parts
Here, I would ask for further clarification: Are there explicit tests or practical evidence that these kits actually provide good adhesion and color fastness on KALLAX surfaces? Many products that work well on particleboard often have limited adhesion on melamine.
Melamine has a very smooth surface, which makes it difficult for paints and fillers to mechanically bond. I would therefore recommend testing on a small, inconspicuous area first.
Furthermore, is the surface matte or glossy? This strongly influences the choice of repair materials.
Ultimately, the question arises whether a repair might take more time and effort than simply replacing the affected parts affordably or creating a completely new look with decorative films.
Therefore, my constructive suggestion: Consider whether a partial overlay with self-adhesive decorative films could be a durable and aesthetically pleasing solution. This saves effort and preserves the original structure.
What do you think?
