ᐅ Multi-generational house with an underground garage for three families
Created on: 11 Mar 2019 09:55
Muc1985
After reading quietly for a while and really appreciating all the ideas shared here, I’d like to bring up a topic and hopefully get some feedback, suggestions, and ideas!
I am 34 years old and originally from Munich, where I was born and raised.
Currently, we (my wife and I, with a child on the way, my sister and her partner, as well as my parents) are discussing whether to completely rebuild on our plot of land (currently occupied by a single-family house / 1000 sqm (0.25 acres) / 20 × 50 m (65 × 164 ft) / no zoning plan). The idea is to build a fairly modern house with two spacious living areas (each with its own terrace overlooking the garden, large living and dining areas, etc., and about 200 sqm (2150 sq ft) of living space), including an underground garage and a basement. A granny flat (or accessory dwelling unit) is also planned to be integrated.
I would like to start a discussion based on these ideas and am looking forward to any input or constructive criticism.
Thank you very much.
Pinkiponk
10 Nov 2020 19:54
Silly question, you probably know anyway ;-)
If I may humbly presume to translate for 11ant: Yes, it is very interesting. :-)
pagoni2020
10 Nov 2020 20:07
Pinkiponk schrieb:
If I may humbly presume to translate 11ant
...but it could also have been done electronically; meanwhile it is also available online at "Kuukel-Translate" as an additional language.....right after Gaelic
Climbee11 Nov 2020 09:40
But hellooo! Of course, it matters!!!!
Muc1985
11 Nov 2020 16:53
Here is the general idea of how it should look. This is the "less attractive" side and the view from the street.
Moderne Mehrfamilienhaus mit grauen Fassaden, großen Balkonen und Garten
Muc1985
15 Nov 2020 21:06
As briefly mentioned before, here are some details on how our project is planned. It will consist of two stories plus a recessed top floor and an underground garage (and basement areas) with a flat roof. The construction method is solid masonry, using thermal bricks. Our gross floor area will be approximately 1,050 m² (11,302 sq ft). Including balconies, the gross floor area will be around 1,200 m² (12,917 sq ft). The gross floor area of the underground garage (a small part had to be slightly extended beneath the building) is about 230 m² (2,476 sq ft).
The living area, including half of the hobby rooms in the basement and the proportional terrace and balcony areas, amounts to approximately 620 m² (6,673 sq ft).
K1300S16 Nov 2020 07:34
How many vehicles is the underground garage designed to accommodate? A portion of the 230 m² (2,475 sq ft) will also be used as driveways and circulation space.
