ᐅ Installing a Carport on a Prefabricated Timber Frame House?
Created on: 31 Aug 2018 10:06
trendyandi
trendyandi
31 Aug 2018 10:06
Now that we can finally start planning the carport, I have a basic question and would like to know your opinion…
A brief overview: we have a prefabricated house (prefab house Weiss) with timber frame construction (built in 2014). The carport will likely be made of aluminum, measuring 7 x 3.50 m (23 x 11.5 ft) with an 8mm (0.3 inch) laminated safety glass (VSG) roof.
We would prefer to attach the carport directly to one side of the house, which should be possible structurally due to the wooden beam running along this side of the house. However, the homebuilder recommends a freestanding structure in front of the façade for the following reasons:
- With such constructions, the later connection or choice of fasteners can be problematic, as the fasteners may no longer be able to bear the loads
- Insulation (ETICS / external thermal insulation composite system) would have to be damaged at these points
What do you think about this?
Last year, we had a pergola awning installed directly on the wall. They used spacers/distance sleeves to avoid compressing the insulation. So far, it’s holding up perfectly! : -)
Greetings from the Swabian region!
trendyandi
6 Sep 2018 11:25
Hello everyone!
Too bad, no replies yet! I would be happy if someone could add something here ; - )
Domski
6 Sep 2018 11:55
The structural engineering of a prefabricated house may allow for this, but it is usually never verified through detailed calculations. However, if you have had these calculations performed, then the issue of insulation and the durability of the fixings becomes purely a matter of craftsmanship.
Plan all connections with adequate dimensions, execute them correctly according to best practices, and ensure weather protection through proper design. However, the version "freestanding with a 2mm (0.08 inch) air gap" involves fewer possible errors and is also easier to construct.
hanse987
6 Sep 2018 12:36
Do you know exactly where the beam runs, and does it line up properly with the height of the carport?
I wouldn’t screw it directly to the house. I would even leave a bit more than 2mm (0.08 inches) of clearance—around 5cm (2 inches). Due to wind load, all structures move slightly, and with a very small gap, there’s a risk that the plaster could eventually get damaged.
Domski
6 Sep 2018 12:48
Neither a carport nor, even more so, your single-family house should shift by several millimeters (inches) due to wind… That would indicate a completely different problem.
6 Sep 2018 12:49
trendyandi schrieb:
- Insulation (ETICS) must be damaged at these points
For this reason, our carport is also freestanding on its posts. There is about 3 cm (1.2 inches) of space between the house and the carport... who cares? Not us, no one sees it.
