ᐅ Malm Furniture with Surface Stains – How Do I Clean It Properly?
Created on: 28 Jun 2022 09:27
Rureo
Rureo
28 Jun 2022 09:27
I have a Malm piece of furniture from IKEA that, unfortunately, has developed some surface stains due to everyday use. These are light discolorations, apparently liquid marks and small grease spots on the veneered surface, which I cannot remove simply with a damp cloth.
I am particularly interested in cleaning methods that are both gentle and effective, without damaging the surface or affecting the material. Are there any special cleaning products, home remedies, or techniques that have proven successful?
I want to preserve the furniture and avoid causing stains or damage through overly aggressive cleaning agents. Perhaps someone has experience with Malm furniture or similar surfaces and can offer advice on the best way to treat these types of stains?
naujon
28 Jun 2022 10:45
Hello Rureo,
great that you want to properly care for your Malm furniture! Here is a structured guide for stain removal on veneered surfaces, as typically found on Malm pieces:
1. Basic cleaning: Start by wiping the surface with a soft, slightly damp microfiber cloth to remove dust and loose dirt. Avoid abrasive cleaners or rough cloths, as these can cause scratches.
2. Stubborn stains: For water or grease stains, you can use a mild dish soap: add a few drops to lukewarm water and gently wipe with a well-wrung cloth. Be sure to follow up with a dry cloth to prevent moisture from soaking into the surface.
3. Specific stains: For tougher stains, diluted vinegar (1:1 with water) may help, but be careful! Always test first in an inconspicuous spot. Vinegar is mildly acidic and prolonged exposure can dull the finish.
4. Maintenance: After cleaning, you can use a wood surface polish that seals the wood and helps prevent future stains. These products are available at hardware stores.
Important: Never leave furniture wet; always dry thoroughly.
If you have very stubborn stains, just let me know, and I can give you more targeted advice.
Good luck!
Jorgela
28 Jun 2022 11:12
I would recommend avoiding aggressive chemicals. A damp cloth with a little dish soap usually does the job. Afterwards, wipe dry. This way, Malm furniture will stay looking good for a long time.
kulau
29 Jun 2022 07:33
Hello Rureo,
To provide a more detailed answer to your question, I would like to add some important points that are often overlooked and prove crucial, especially with veneered furniture:
You mentioned stains related to water or grease. Veneered surfaces on Malm furniture consist of a thin layer of real wood veneer or decorative foil, which is durable but can be sensitive to prolonged moisture exposure. Therefore, you should always avoid letting water or other liquids sit on the surface for an extended time.
Specifically, this means:
- Use only slightly damp cloths, not wet ones.
- Avoid abrasive cleaners, as they can leave a dull, damaged surface.
- Clean stains quickly before they dry, as this makes removal more difficult.
For grease stains, I recommend a mild solvent, for example, a cotton pad moistened with alcohol (isopropanol), applied briefly and carefully to avoid damaging the veneer. Test this on an inconspicuous spot first.
As Naujon already mentioned, vinegar should be used cautiously because its acidity can leave a matte residue. For more stubborn discolorations, a fine furniture eraser can be tried, but this requires a delicate touch.
Finally, you can apply furniture care products with beeswax or a quality wood treatment to protect the surface and conceal minor scratches.
I’m curious: Is your furniture covered with decorative foil or genuine veneer? And which stains are the most persistent? Have you already tried any specific treatments?
That way, we can offer more targeted help.
Rureo
29 Jun 2022 09:58
naujon schrieb:
For water or grease stains, you can use a mild dish soap: Add a few drops to lukewarm water and gently wipe with a well-wrung cloth.
Thank you for this tip! I will definitely try it, as I have always been too rough so far.
kulau schrieb:
I’m curious: Is your furniture covered with a decorative foil or real veneer? And which stains are the most stubborn? Have you already tried any specific cleaners?
I’m quite sure it’s decorative foil, as these are rather inexpensive Malm dressers. The most stubborn stains are light water marks from spilled drinks and some greasy smudges, for example from skin contact or food residues. So far, I have only tried cleaning with water and regular all-purpose cloths—maybe that was not enough.
If I should try something with alcohol or vinegar, I will test it on an inconspicuous spot first, thanks for the suggestion!
Does anyone have experience specifically with decorative foils and how they react to cleaning agents?
reoleon47
30 Jun 2022 15:02
Hey!
It’s great to see you taking such good care of your furniture! 🙂
I had similar stains on my Malm bedside table – also covered with decorative foil. I tried warm water with a little dish soap, then polished it with a dry cloth. It was important for me to always let the furniture dry thoroughly afterward.
Some people also use furniture care products designed for laminate that are very mild. However, I wouldn’t recommend strong chemicals, as they made the surface slightly dull for me.
It sounds like you’re on the right track! Keep at it and don’t give up—those stains usually come off with patience 😉
I’m looking forward to seeing how it goes for you!
