ᐅ Malm Dresser only Squeaks when Pressure is Applied – Possible Causes?
Created on: 10 Dec 2020 08:37
Bradli
Hello everyone, I have the following issue with my IKEA Malm dresser: When I apply pressure to the drawers, for example when opening them or gently pushing or pulling them, the drawer squeaks. The noise only occurs when I actually put force on the runner or the drawer bottom, so it doesn’t happen during normal opening without pressure. My question is: What could be causing this squeaking? Could it be the drawer runner, the assembly, or maybe a specific area that has deformed over time? I have read before that wood on wood, metal on metal, or dry runners can cause such noises. Tips for accurately diagnosing or identifying the cause would be much appreciated. Thank you!
Bradli schrieb:
Can drawer installation, if slightly misaligned, cause persistent squeaking?Yes, definitely. Especially under pressure, additional forces act on the drawer slide. If the drawer does not run precisely within the slide, tiny shifts or uneven contact pressure can occur under load, which leads to squeaking.
In addition to lubrication, I recommend checking the chest of drawers from all sides for alignment and stability. Small floor unevenness or a slightly tilted position can also contribute to friction noises.
TYRELL schrieb:
I also recommend checking the dresser for levelness and stability from all sides, in addition to lubricating it. Absolutely right, and I would add: if necessary, use washers or small wedges to level the dresser. This prevents additional unnecessary stress on the guides.Update: I have now checked and slightly tightened all the screws. Then I applied silicone spray to the metal rails and ball bearings. After that, I placed the chest of drawers on a level stone floor and experimented with small felt pads on the contact points.
The squeaking is noticeably reduced and only occurs under very strong pressure. I believe I have identified the main cause: a somewhat loose assembly combined with insufficient lubrication.
Thank you all very much for the detailed explanations and tips! They really helped me to pinpoint and solve the problem.
