ᐅ The Malm bed is squeaking – how can I fix the problem?
Created on: 7 Mar 2020 07:33
Gitatsuo
Gitatsuo
7 Mar 2020 07:33
Hello everyone, I have a Malm bed from Ikea that has been creaking with every movement for some time now. The noise mainly occurs when getting up or turning over in bed and is quite annoying. I have already tried tightening the screws slightly, but that didn’t help much. Is there a systematic approach or specific areas to check and maintain in order to eliminate this creaking? Maybe suitable lubricants or assembly tips would also be helpful. I’d like to solve the problem without major disassembly or expensive replacement parts. Thanks in advance for your advice!
Gino38
7 Mar 2020 08:12
Squeaking in a Malm bed can have several causes; typically, such noises result from loose connections or friction between wood and metal. My recommendations:
1. Carefully tighten all screws, especially at the joints between the slatted frame and the bed frame. Wood components can loosen over time.
2. Check that the slatted frame and bed frame fit together properly without any play.
3. Use a dry lubricant such as graphite powder or silicone spray to treat wood-to-wood contact points; avoid oily lubricants as they attract dust.
Disassembly is usually not necessary as long as you work specifically on the main contact points.
miAlessio
7 Mar 2020 08:45
Hello Gitatsuo,
I read your post carefully and would like to respond in a more structured way since I am familiar with the Malm bed myself.
First: The typical creaking usually comes from the joints between the side panels and the headboard or footboard.
Steps you can take:
1. Check the screws: Not only tighten them, but also check if they are still firmly anchored in the wood. Sometimes the thread seat is damaged from overtightening. In that case, a small amount of wood glue in the thread can help. Let the glue dry, then screw the screw back in.
2. Roughen the sliding and rubbing surfaces: Lightly sanding the contact areas where the parts rub against each other can prevent creaking.
3. Insert intermediate layers: Place a thin felt or felt tape between the wooden joints to reduce friction.
4. Lubricants: Silicone oil works well. Never use standard oil, as it can cause the wood to swell or stick.
If you like, I can send you a detailed overview of the most important connection points.
Scarlett
7 Mar 2020 09:17
Gino38 schrieb:
3. Use a dry lubricant such as graphite powder or silicone spray to treat wood-on-wood contacts; avoid oily substances as they attract dust.
Oh yes, that’s true! Especially when I heard a creaking sound, I was unsure what the best solution would be. I am familiar with the fear of causing damage. I really appreciate it when someone provides such clear instructions like you do, Gino38. Don’t worry, sometimes a little patience and a small amount of lubricant in the right spots is all it takes to sleep peacefully again 🙂
V
vinli
7 Mar 2020 10:03
To add and based on my experience:
One should not overlook that the interaction between the slatted bed base and the bed frame can also cause noises.
Check whether the slats or the slatted base itself are firmly fixed. Movements on the bed can cause slats to become loose or rub against each other.
A systematic approach:
- Check fasteners with a torque tool
- Readjust spiral connectors if necessary
- Inspect wooden battens for damage
In persistent cases, lightly applying a thin layer of beeswax to the contact surfaces can help. This significantly reduces friction without negatively affecting appearance or durability.
batabe
8 Mar 2020 11:21
Good morning!
I have put together a step-by-step guide that often helps with Malm beds:
1. Disassemble the bed: remove the headboard, footboard, and side rails.
2. Lightly clean the wooden parts, especially at the joints.
3. Unscrew the screws by hand and clean the threads.
4. Check all screws for damage again and replace if necessary.
5. Gently sand the wooden joints with fine sandpaper if the surface is damaged or rough.
6. Apply a small amount of graphite powder to the contact surfaces before reassembly.
7. Carefully reinsert the screws without applying excessive force.
I recommend taking your time with this process. Usually, the squeaking stops permanently. If you’re unsure, feel free to reach out again!
