ᐅ Looking for wall-mounted lights for the living room, hallway, and stairway areas.
Created on: 3 Mar 2016 10:03
Sebastian79
Sebastian79
3 Mar 2016 10:03
we are a bit overwhelmed by the sheer number of lighting options, as it’s been quite difficult to find something suitable.
In the living and dining area, we have 6 wall lights, in the ground floor hallway another 4, and 2 on each stair landing.
At least in the living/dining area, I would like to have matching lamps, but I wouldn’t mind if all the lamps were the same.
In the hallway, we also have downlights installed in the concrete ceiling, in the living room there is a ceiling outlet, and of course there is lighting at the dining table, so none of the lamps necessarily need to be for bright, festive lighting.
It’s important that all of them (except possibly on the stairs) are dimmable, and ideally use replaceable bulbs – but that’s not a requirement.
We would really appreciate a few tips.
Jochen1043 Mar 2016 10:09
Hello Sebastian,
Here is also my recommendation for the online store "Lampenwelt." I have had very good experiences there. The phone support was helpful as well, and the prices are fair.
Which lamp you choose, as often, is a matter of personal taste.
Sebastian79
3 Mar 2016 10:11
Yeah, thanks – I’ve already ordered two lamps from them. The only issue was that the delivery times were a disaster every time. Their prices were always unbeatable – for our recessed floor lamp in the living room, some wanted nearly double the price.
Of course, it’s a matter of personal taste, but maybe someone here has a great tip.
Jochen1043 Mar 2016 10:33
Sebastian79 schrieb:
Only the delivery times were a disaster every time
I’ve never had any problems with that either
Their prices were unbeatable – some wanted almost double for our recessed floor lamp in the living room.
One more tip: If you order larger quantities, call ahead and ask for a quote. I managed to get an extra 15% off the online price on our recessed spotlights and bulbs.
V
Vanben
5 Mar 2016 10:36
This style is quite specific in terms of taste, but I’d like to suggest something like this:
You can even build these parts yourself fairly easily if you’re interested. The advantage: it’s relatively inexpensive, and you’re hardly limited by the shape or design. All you need are the appropriate fittings, some wiring, and a few lamp sockets.
You can find quite a bit on Google under the term “steampunk lamp.”
Industrial wall lamp with perforated metal shade and warm bulb light
Upcycled lamp: two glass bottles as lamps, red glow, pipe valve connection.
Umbau-Susi5 Mar 2016 13:43
Just got back from buying lamps again (3 years after moving in).
We still don’t have a living room lamp and, until today, we were missing a wall lamp above the bed that can provide either indirect light or reading light.
We finally solved the second problem today. We chose a 53 cm (21 inches) long Honsel Pare (18.9W LED, 1800 lumens, 3000K), which can be rotated upwards for indirect light or downwards for reading. It was also important to us that the lamp has its own switch. I’m so relieved that this is finally done.
Hopefully, the living room lamp issue will be resolved by the 4th anniversary of moving in as well.
