ᐅ Hanging Light Fixtures – Electrician Cost Estimate
Created on: 27 Jan 2019 16:06
Blankenhuter
Blankenhuter
27 Jan 2019 16:06
My wife and I were thinking over the weekend about how we want to handle the lighting. Neither of us are skilled tradespeople, and we don’t personally know an electrician who could help us. We have about 20 lamps to be installed throughout all rooms and corridors. How much should it roughly cost if an electrical company does the work on site? (This is not about purchasing the lamps, just the interior installation).
Before we request quotes, we want to get a general idea of the expected cost. The less knowledge you have, the higher the risk of being charged an excessive price (for example, the price range from different companies for installing a circulation pump was between 500 and 1500 euros net).
Knöpfchen27 Jan 2019 16:39
Well, good question, next question.
Just assume at least half an hour per light fixture.
You might as well ask: How old is the captain.
Domski
27 Jan 2019 16:46
Half an hour per light fixture is realistic if it’s done nicely. For complex lighting systems, it can take a bit longer. For example, I have PAULMANN LED spotlights, where I extended the original wiring with 20cm (8 inches) of HV05 cable into a small separate junction box with a terminal block because the original connection space designed for standard NYM cable was too small. I needed more time per spotlight due to that.
Then calculate around €50 per hour plus some travel costs to get a realistic price.
Nordlys
27 Jan 2019 20:26
Buy lamps from him, and the installation will be cheaper. Want to bet? That’s been my experience. We bought two outdoor lamps, several spotlights, one dimmable ceiling lamp and two non-dimmable ones, as well as some lamps for the garage and floor from him, and he didn’t charge anything for installing them. I also had four lamps from Ikea lying around, which his assistant installed for a small tip, so everything was ready. K.
O
Obstlerbaum
28 Jan 2019 08:32
So, in my opinion, installing a lamp is not rocket science. Just always follow the first rule: turn off the circuit breaker.
Domski
28 Jan 2019 09:42
For hobby DIYers, installing a lamp is no big deal... BUT:
The original poster doesn’t feel confident and is doing the only right thing by calling in professionals.
Because: electricity can hurt you badly, cause burns, or worse, if something goes wrong.
