ᐅ Looking for a sturdy and large patio umbrella or cantilever umbrella
Created on: 5 May 2022 19:55
Stefan67422578
Stefan67422578
5 May 2022 19:55
our new southwest-facing terrace is almost finished. It is 4.2m (14 feet) deep and 9m (30 feet) wide.
Later, we would like to have a lounge area. However, for now, we would like to have a sun umbrella since summer is approaching quickly.
It is important that the umbrella is sturdy and does not twist or turn at the slightest breeze. Most likely, a cantilever umbrella would be the best option, right?
What do you recommend?
O
Obermuh
5 May 2022 21:41
How much of your terrace do you want to shade? Should the umbrella be portable?
How much are you willing to spend?
Whether to choose a cantilever umbrella or another option also depends on the local conditions.
I’m using two Schneider Rhodos umbrellas (one Twist 3x3m (10x10ft) and one Grande 4x3m (13x10ft)) and have been very satisfied so far. Both can rotate 360 degrees and tilt; the Twist model also tilts sideways, which allows me to block the sun at all angles. Both are installed in concrete bases but can also be used with a freestanding base.
Glatz is considered top of the line but is priced accordingly. Just the wheeled base from Glatz costs more than my entire umbrella.
i_b_n_a_n5 May 2022 21:47
Obermuh schrieb:
Glatz is probably the ultimate, but it also comes with a high price. The rollable Glatz base alone costs more than my entire umbrella 😉
The "standard" Glatz base, however, is absolutely overpriced when you look at the quality of workmanship and choice of materials. If that’s supposed to be top of the line—well, puh! (My brother has one, I was actually holding it for a party today, and he was quite (very) disappointed when it was delivered back then. The umbrella itself is very sturdy and well designed, also in terms of materials, but the base…
Stefan67422578
5 May 2022 21:51
I am currently looking at the Schneider Rhodos Grande and the Outflexx in 400x300cm (13x10 feet). Both are similarly priced. The Outflexx apparently has the better fabric, with 250g/m² instead of 200g/m² for the Schneider, and a UV protection rating of 80+ compared to Schneider’s 50+.
My budget range is around 600-700 Euros.
I find it a pity that neither of them can tilt sideways like the Twist model. The Twist would be too small for me at 3x3m (10x10 feet). How well does the Schneider perform in windy conditions?
Also, is it possible to equip the Schneider with a retractable foot?
O
Obermuh
6 May 2022 07:11
i_b_n_a_n schrieb:
The standard Glatz base, considering the quality of workmanship and choice of materials, is absolutely overpriced. If that’s supposed to be top of the line—well, puh? (My brother has one, I actually held it for a party today, and my brother was quite (very) disappointed when it was delivered back then. The canopy itself is very sturdy and well thought out in terms of materials, but the base…
The included base is actually pretty basic, but the rollable Glatz stand, at least when I looked at it, is of very high quality. Still, almost €1000 without plates is massively overpriced 😉
Stefan67422578 schrieb:
I also currently have the Schneider Rhodos Grande or the Outflexx in 400cm x 300cm (approximately 13ft x 10ft). Both are similarly priced. The Outflexx apparently has the better fabric—250g/m² instead of 200g/m² on the Schneider, and UV protection of 80+ compared to Schneider’s 50+. My price range would be around €600-700. It’s a pity that neither can tilt sideways like the Twist model. The Twist would be too small for me at 3m x 3m (approximately 10ft x 10ft). How does the Schneider hold up in wind? Also, can you get a rolling base for the Schneider?
You can mount the umbrella on any base with the appropriate drilled holes.
Moderate wind is not an issue; with the optional wind stabilizer, you can further secure it. However, due to their design, cantilever umbrellas tend to perform worse in wind, especially gusts.
rick20186 May 2022 12:52
Glatz is great. But an umbrella measuring 4x4 meters (13x13 feet) requires a foundation weighing between 600 kg and 1000 kg (1320 lbs and 2200 lbs).
Therefore, the movable base is huge. But it’s not easy to move...
We have the sleeve for embedding in concrete. There is now also a joint available for this.
Overall, you currently have to expect costs over $10,000. For most people, this exceeds the budget for a sun umbrella.
The question is whether an awning covering half the terrace might be more practical. It’s certainly not more expensive.
