ᐅ Kitchen Photos Thread – Show Us Your Kitchens!
Created on: 16 Aug 2018 10:03
DieScholz´ens
Bought a house, estimated the renovation budget plus 10-15% for inevitable extras, and we set aside 5000 EUR for the kitchen!!!!
That’s how it started... at first, I was in a bit of shock, but we still had time. First step: remove all the walls for a new layout—I need space...
Let’s start with the (according to the agent) move-in ready property. The small kitchen, just under 8 square meters (about 86 square feet), had its 1970s pass-through removed. The wall including the kitchen door is gone! The wall next to the cellar stairs is gone too! Actually, the entire slanted wall, nearly 7 meters (23 feet) high, removed completely...
The window had to go as well since we needed a different working height than the standard 90 cm (35 inches). New screed installed, we switched to underfloor heating, all electrical wiring and water pipes are new.
After almost six months, the realization slowly sank in: the kitchen budget will not exceed 5000 EUR, so we had to look for a used kitchen... something special, but very cheap.
The search criteria: within a 100 km (62 miles) radius, up to 1000 EUR, because I still want new appliances.
Open living area with modern white kitchen, bright flooring and lots of light
Kitchen area with red tiled backsplash, white base cabinets and window
Bright, empty living room with white walls, laminate flooring and built-in shelf.
Bathroom under construction with floor tiles, red wall tile and sanitary connections
Kitchen shell with tiled floor, building materials and open ceiling during renovation
Construction site inside house with bare walls, cables and construction waste.
Child in winter jacket looking at unfinished interior with exposed walls and construction work.
Two workers renovating interior; exposed walls, tools and cable reels visible.
Interior finishing and remodeling: construction work in renovated space with open installations.
16 Dec 2019 22:05
Schlenk-Bär schrieb:
Can someone say how many square meters that is? I would like to know if I'm misestimating....
Why ask someone? Just ask the builder @Climbee
Schlenk-Bär
17 Dec 2019 08:31
@Climbee How large is the kitchen? Thanks.
Climbee17 Dec 2019 08:50
Our plan shows 13.4 sqm (144 sq ft) allocated for the kitchen.
The kitchen countertop along the window is 327 cm (129 inches) long, plus the two tall cabinets, which add approximately another 120 cm (47 inches).
The island is 330 cm (130 inches) long and 120 cm (47 inches) deep. The distance between the two kitchen workspaces is somewhere between 125 and 128 cm (49 and 50 inches).
fresh2
23 Dec 2019 08:16
Here is our new kitchen. It’s from Ikea and we assembled it ourselves. Only the wall trim and baseboard finishes are still missing. A white bar top will also be added at the passthrough. The kitchen measures just under 8 m² (86 ft²).
Kitchen with wood countertop, white cabinets, sink, and colorful leaf wall art.
Kitchen with white tall cabinet wall, built-in oven, stone wall on the right, colorful leaf wall behind.
Kitchen with white cabinets, glass doors, coffee maker, fruit bowl, sink, and textured wave wall.
Kitchen with induction cooktop, extractor hood, white cabinets, tiled wall, colorful leaf wall in the background.
Kitchen seen through wall opening: fruit bowl on wood counter, smartphone, calendar, colorful leaf wall.
haydee
23 Dec 2019 08:22
The advent calendar is good
Bookstar
23 Dec 2019 09:09
The kitchen would be far too small and cramped for me; when cooking together, you just get in each other's way. However, we used to have something similar because there was no other option.
