ᐅ Kitchen Photos Thread – Show Us Your Kitchens!
Created on: 16 Aug 2018 10:03
DieScholz´ens
Bought a house, estimated the renovation budget plus 10-15% for inevitable extras, and we set aside 5000 EUR for the kitchen!!!!
That’s how it started... at first, I was in a bit of shock, but we still had time. First step: remove all the walls for a new layout—I need space...
Let’s start with the (according to the agent) move-in ready property. The small kitchen, just under 8 square meters (about 86 square feet), had its 1970s pass-through removed. The wall including the kitchen door is gone! The wall next to the cellar stairs is gone too! Actually, the entire slanted wall, nearly 7 meters (23 feet) high, removed completely...
The window had to go as well since we needed a different working height than the standard 90 cm (35 inches). New screed installed, we switched to underfloor heating, all electrical wiring and water pipes are new.
After almost six months, the realization slowly sank in: the kitchen budget will not exceed 5000 EUR, so we had to look for a used kitchen... something special, but very cheap.
The search criteria: within a 100 km (62 miles) radius, up to 1000 EUR, because I still want new appliances.
Open living area with modern white kitchen, bright flooring and lots of light
Kitchen area with red tiled backsplash, white base cabinets and window
Bright, empty living room with white walls, laminate flooring and built-in shelf.
Bathroom under construction with floor tiles, red wall tile and sanitary connections
Kitchen shell with tiled floor, building materials and open ceiling during renovation
Construction site inside house with bare walls, cables and construction waste.
Child in winter jacket looking at unfinished interior with exposed walls and construction work.
Two workers renovating interior; exposed walls, tools and cable reels visible.
Interior finishing and remodeling: construction work in renovated space with open installations.
Alessandro
1 Oct 2020 08:20
Not too bad in winter. I like the kitchen. Black in the country house style is not often seen.
Pierre
1 Oct 2020 10:18
I hope you don’t have too many issues with fingerprints on the black fronts. In my opinion, you can clearly see some on the flap above the oven in the pictures.
Bookstar
1 Oct 2020 10:43
A black kitchen is an absolute nightmare to clean! Unfortunately.
Alessandro
1 Oct 2020 11:14
That was also the only reason why we ultimately decided against a black kitchen.
halmi
1 Oct 2020 11:50
We have a black kitchen with glass fronts, which I have already posted about here, and I don’t find it particularly demanding to maintain; the glass fronts are very easy to clean.
Grobmutant
1 Oct 2020 12:54
The kitchen looks stylish and very elegant.
It appears a bit dark in the photos, but that might be misleading.
Can the faucet be rotated so the window can be fully opened? Or can it only be tilted?
