ᐅ KALLAX on casters is too tall for my niche – any tips?
Created on: 30 Aug 2024 09:12
Bimarion
I have the following issue: I own a KALLAX shelving unit that I fitted with casters to make it easier to move when needed. The problem is that with the casters, the shelf unit is now too tall for my niche in the apartment. The niche measures about 180 cm (71 inches) in height, while the KALLAX with casters is approximately 190 cm (75 inches) tall. So, the shelf does not fit.
However, I don’t want to give up the mobility provided by the casters or replace the shelf with a different one. Therefore, my main question is: Are there practical ways to lower the height of the KALLAX with casters a bit without significantly compromising stability or functionality?
Possible approaches could include using different casters, modifying the casters themselves, or perhaps cutting or adjusting the shelving structure. What are proven solutions in practice? Are there any tips or recommendations on what to watch out for?
I look forward to your advice and experiences!
Bimarion
31 Aug 2024 10:50
Great tips, thanks to everyone!
For me, the first step would probably be to try replacing the casters with flatter ones while simultaneously shortening the legs slightly.
The idea of adding a base sounds interesting, but I’d prefer to avoid that for now to keep the effort minimal. I could then be more flexible with the next move.
Wall mounting will definitely be implemented.
If anyone has experience with casters around 3–4 cm (1.2–1.6 inches) in height and suitable load capacity, I’d appreciate any specific recommendations. :-)
flo-Theres
31 Aug 2024 12:14
I use casters with a build height of about 3.5 cm (1.4 inches) for a similar KALLAX shelf (load capacity 30 kg (66 lbs) per caster). Important: the caster should have a twin-wheel mechanism, as this reduces strain and provides better stability.
You can find these casters, for example, at specialized furniture caster shops or on Amazon under "flat furniture casters 35 mm (1.4 inches)".
Installation is usually straightforward, but these casters are somewhat more expensive than the standard IKEA casters.
Make sure the diameter of the mounting plate matches the existing holes, otherwise you will need to modify the installation.
gasidney
31 Aug 2024 14:07
For mobility and low construction height: flat castors with ball-bearing wheels. These significantly ease pushing.
Bimarion
1 Sep 2024 08:03
Last update from my side:
I ordered casters with a 4 cm (1.5 inch) mounting height and will shorten the legs by about 2 cm (0.8 inch). This way, I should stay under the 180 cm (71 inch) limit. I will maintain stability through wall mounting and the secure fit of the casters.
Thanks for all the helpful tips; they have been very useful!
