ᐅ KALLAX with frequent assembly and disassembly – how durable is it?
Created on: 26 Jun 2021 19:37
PeogoHello everyone,
I am currently looking into how durable the IKEA KALLAX shelves are when frequently assembled and disassembled. Specifically, I am interested in how many times a KALLAX shelf can withstand repeated setups and takedowns without losing stability or strength in the connection components (such as the connector clips and screws). I am aware of the issue with some furniture where the fastenings become loose after multiple disassemblies or the wood around the drill holes gets damaged.
Does anyone have experience with how robust the KALLAX piece is under frequent transport and repeated assembly? How many build-ups and breakdowns are realistically possible before noticeable wear or loss of function should be expected?
Additionally, I am interested in any recommended tips or measures to minimize damage to the connection points. For example, special lubricants, reinforcements, or replacement parts.
I look forward to your feedback, especially from those who regularly move KALLAX units or set them up and take them down for events.
Thank you and best regards!
Peogo schrieb:
how long a KALLAX shelf can withstand repeated assembly and disassemblyWith careful handling and not too frequent assembly and disassembly, the KALLAX can easily last for several years.
Peogo schrieb:
are there any recommended tips or measures to minimize damageDo not overtighten the screws and check them with each assembly. Avoid overloading the joints.
Hello Peogo,
I completely understand your concerns, as KALLAX shelves are made from coated chipboard, which can wear out somewhat with frequent assembly and disassembly.
Here are a few tips based on my experience:
1. Pay attention to the screw holes: These are the weak points and tend to widen after multiple assemblies. Always loosen and tighten screws carefully without over-tightening.
2. Use thread locker: A small drop of screw thread adhesive can help secure the screws without causing them to stick, striking a good balance.
3. Reinforce with additional brackets: If you frequently assemble and disassemble devices, attaching small metal brackets on the inside of the back panels can improve overall stability.
4. Protect during transport: Avoid impact stresses on the edges, as the coating can crack more easily.
5. Replace connector clips as needed: KALLAX connectors are available separately; once one wears out, it’s best to replace it rather than continuing to use worn parts.
Overall, about 10 to 15 complete assemblies and disassemblies are realistic without significant damage if handled carefully. After that, minor play or fraying may occur.
I hope this helps! 🙂
bulanau schrieb:
about 10-15 complete assemblies and disassemblies realistically, without major damageI completely agree! 🙂 I have taken down and rebuilt my KALLAX for events at least 12 times so far, with no issues, as long as you work carefully.
The key is to take your time and avoid forcing anything. Minor scratches or dents are to be expected and are normal with frequent use.
You shouldn’t overdo it, but for normal event use, the shelf is sturdy enough! So don’t worry, just get started with the assembly! :-)
