I’m currently facing an issue with my IKEA KALLAX shelf after moving. Unfortunately, it got a crack on one corner during transport that runs through one of the side panels. The shelf is still somewhat stable, but I’m worried that it might eventually fail completely, especially since I’m storing a fair amount of weight on it (books, decorations, etc.).
My question to the community: What are the best ways to effectively reinforce a cracked KALLAX frame without fully dismantling or replacing the furniture? Does anyone have tips on suitable reinforcements, such as wooden strips, metal brackets, or special adhesive techniques? Any advice on the best materials or methods would be greatly appreciated.
Thanks in advance!
Thanks in advance!
Basically, when a side panel of a KALLAX unit is cracked, it is important to restore its stability quickly to prevent any safety hazards.
My recommendation:
1. Thoroughly apply a high-quality wood glue (e.g., polyurethane glue) to the cracked area.
2. Then, clamp the part firmly to ensure an optimal bond.
3. After drying (at least 24 hours), I recommend reinforcing the cracked area on the inside with a thin but sturdy metal bracket.
4. For those skilled in DIY, covering the inside with narrow strips of plywood can provide additional stability.
When working with official KALLAX units, always keep in mind that they do not have the load-bearing capacity of solid wood furniture. Overloading should be avoided.
My recommendation:
I can confirm this approach but would like to add the following:
In addition to the measures already mentioned, it is also possible to reinforce the area around the crack using flat metal strips or thin wooden slats. These can either be screwed on (carefully, to avoid further damage to the material) or glued, with gluing using high-quality wood glues and proper clamping techniques generally providing a more durable and stable result.
Furthermore, it is advisable to completely unload the shelf during the glue’s drying time, meaning no weight from books or decorations should be applied.
If the damaged part is a side panel used for connecting to other elements, stabilizing the connection points should be given particular priority.
Hello Tigemar,
I completely understand your concern. KALLAX is indeed a sturdy shelf, but as nubar and SUBEN60 have already mentioned, the material is more of a veneer-coated particleboard composite, which can quickly lose stability when it develops cracks.
If you decide to reinforce it with wooden battens, please make sure to use appropriate wood glue and screws with a small diameter.
My advice: Don’t forget to pre-drill to avoid further splitting the wood. Additionally, for stability, it’s best to install one or two cross braces inside (if the shelf is that long) to counteract lateral pressure.
If you like, I can also provide step-by-step instructions on how to do this in practice.
nubar schrieb:
The shelf does not pose a dangerThat’s exactly what you want to avoid 😅!
A combination of wood glue and metal corner brackets might work really well. I once repaired a somewhat worn IKEA shelf at home with metal brackets on the corners. I screwed the brackets on the inside corners and taped them on the outside until the glue dried – it didn’t look like a design award winner, but it’s still holding up today.
Sure, it’s visible, but sometimes that’s simply the quickest and most effective solution 😊!
