ᐅ KALLAX Temporarily Repaired After Water Damage – Is It Enough?
Created on: 21 Sep 2019 14:07
FatarI recently had water damage and had to make temporary repairs to my KALLAX shelving unit because it warped and swelled in some areas due to the water. My main question is: Is this provisional repair, which mainly involves drying and minor reinforcements, actually sufficient to ensure the stability and function of the KALLAX furniture long-term, or would it be better to replace the entire unit? I want to avoid causing larger damage or risks of collapse later due to a wrong assessment. Has anyone had similar experiences and can share insights about durability and potential risks?
Fatar schrieb:
Is this temporary repair on the KALLAX furniture piece ... sufficient to ensure long-term stability and functionality?These types of shelves are usually made from particle board. If the material has swollen, drying often doesn’t help much. I would recommend replacing the shelf, especially if stability is important.
Genevieve22 Sep 2019 09:31Tobias schrieb:
If the material has swollen, drying usually helps little.That is mostly true, but I wonder what kind of repair was actually done. In my opinion, just drying and minor reinforcements rarely suffice to absorb mechanical stresses over the long term.
Fatar schrieb:
I want to avoid that a wrong assessment later causes bigger damage or risk of collapse.That is an important point. The aspect of long-term stability should not be underestimated. How exactly was it reinforced? For example, were metal brackets or wood glue used, or was it only stabilized superficially?
Perhaps it would be wise to thoroughly inspect the current condition before making a final decision. From my experience, superficial repairs on such materials often represent only a short-term solution.
Fatar schrieb:
whether the temporary repair on the KALLAX will hold up in the long termHey, I once had a water incident with my shelf too, and the KALLAX really didn’t handle it well. 🙂 My advice: if you’ve only done a quick dry and some minor reinforcement, that might be enough if it’s not heavily loaded. But if it gets used frequently, I wouldn’t risk a lot of wobbling.
A “do it quick and clean” approach is sometimes fine, but safety comes first. 🙂 Maybe check if nothing creaks or is uneven. And if it does, replacing it isn’t a problem—KALLAX actually looks pretty good new as well.
So, good luck! 🙂 And don’t stress too much—using a balanced mix of repair and replacement is the safest bet.
