ᐅ KALLAX squeaks against the wall after modification – any advice?
Created on: 16 Apr 2023 18:07
Gisele
Gisele
16 Apr 2023 18:07
I recently moved my IKEA KALLAX shelf to a different wall in my apartment, and since then it occasionally squeaks when I lean on it lightly or pull out a piece. The noise sounds like the shelf is rubbing against the wall or something inside the shelf is sticking. This never happened in its previous position. I have already checked whether the shelf is standing properly on the floor and if anything is stuck, but I didn’t find anything unusual.
Do you have any tips on how to prevent or at least reduce the squeaking in its new location? I would like to avoid damaging the screwed-together shelf if the squeaking is caused by stress or friction. Thanks in advance for your advice.
Friedrich
16 Apr 2023 18:34
Hello Gisele,
I am familiar with this problem; sudden squeaking after moving furniture can be really frustrating. It could actually be due to tension between the shelf and the wall or because the shelf is placed on a slightly uneven surface, causing it to wobble or rub slightly.
Sometimes attaching small felt pads to the contact points between the shelf and the wall helps a lot, as it dampens the noise significantly. Another option is to use thin rubber or foam strips to reduce friction between the shelf and the wall.
It is also important to make sure the shelf is perfectly square— even small tilts can cause noises when leaning on it.
It’s understandable that you don’t want to damage the shelf. How does the structure feel? Are there any visible tensions, warping, or bending anywhere? Personally, I find these kinds of adjustments often stressful because the source of the squeaking isn’t immediately obvious, but with some patience, it usually can be resolved.
joro10
16 Apr 2023 19:01
Stick felt pads onto the shelf on the wall to prevent any rubbing.
CARLA
16 Apr 2023 21:23
Gisele,
there are some technical approaches you can consider:
1. Checking the floor level: If the shelving unit is not standing evenly, pressure points can create tension that leads to squeaking.
2. Adjusting the leveling feet: The KALLAX has adjustable feet. Careful fine-tuning can help align the shelving precisely and relieve contact points.
3. Measuring the distance to the wall: KALLAX units are designed for close placement without direct rubbing against the wall. A very tight gap can cause friction noises.
4. Adding material layers: As suggested, felt or foam pads are effective. They also help prevent damage.
If you want, I can also provide a brief overview of possible leverage effects on the shelving that may cause noises over time when leaned on firmly. However, I recommend trying the simpler solutions before considering extensive modifications.
Gisele
17 Apr 2023 07:56
Friedrich schrieb:
Sometimes it helps to attach small felt pads at the contact points between the shelf and the wall, which significantly reduces noise.
That sounds good, thanks. I’m just hesitant to stick anything on the wall because the wallpaper is delicate. But I could attach them to the shelf frame.
CARLA schrieb:
The KALLAX has adjustable feet. These can help to precisely level the shelf and relieve pressure points by fine-tuning.
I haven’t checked that yet, but I’ll do it today.
joro10 schrieb:
Stick felt pads on the shelf where it touches the wall, then nothing will rub anymore.
I’ll try it that way for now. Does anyone have an idea of the ideal gap to leave between the shelf and the wall? Maybe that could help prevent pressure and warping.
Giagau
17 Apr 2023 10:14
The ideal gap between the KALLAX shelf and the wall should be minimal to ensure stability, but not so tight that the wood is pressed directly against the wall. I recommend a gap of 1 to 2 millimeters (0.04 to 0.08 inches).
To prevent squeaking, felt or foam pads on the sides of the shelf usually help. These absorb movement and reduce friction.
It is also important to regularly check and, if necessary, tighten the screws to prevent even slight movements.
Since you want to protect the wallpaper, it’s better to stick the felt glides onto the shelf rather than the wall. Also, you can check whether the adjustable feet are properly set to avoid any stress buildup.
