ᐅ KALLAX placed on a heating pipe – will the base panel warp?
Created on: 18 Jul 2024 16:42
YANNICK69Y
YANNICK6918 Jul 2024 16:42Hello everyone, I have a specific question about assembling IKEA KALLAX shelves: If you place such a shelf with the base panel directly on a heating pipe, so that the pipe runs underneath the base panel and supports the weight at a single point, is there a chance that the base panel might warp or be unevenly loaded, causing it to bend permanently over time?
I’m asking because I’m considering placing a KALLAX in a corner where a heating pipe runs very close to the floor, and I want to avoid any damage to the shelf’s stability or material.
Does anyone have experience or know whether the construction or material of the KALLAX base panel (medium-density fiberboard with laminated surface) can handle this, or if it would be advisable to install an intermediate layer, for example, to avoid point loads? Thanks in advance for your advice.
sanjon schrieb:
Point loads, such as those caused by heating pipes, can cause it to warp.That is absolutely correct. To explain in more detail: The KALLAX floor panel, as you correctly identified, is made of a medium-density fiberboard, which is relatively thin (about 8-10 mm (0.3-0.4 inches)) and covered with a thin melamine foil. This construction offers a reasonable load-bearing capacity, but point loads lead to local stresses that can cause material deformation.
The issue with heating pipes is that they often become warm, which means the wood fiber material has to absorb additional stress. Heat can also promote moisture exchange within the material, further reducing stability. Additionally, the contact area is very small due to the thin pipe supports, which significantly increases pressure (force per area).
A practical way to avoid this risk is to use an intermediate layer, for example, a thin plywood panel or a hardwood strip placed on the floor beneath the heating pipe location to distribute the load. Alternatively, suitable rubber or felt pads can help reduce pressure peaks.
One final question: Are the heating pipes fixed in place, or can they move with temperature changes? This could further affect stability.
YANNICK6919 Jul 2024 10:12Filippo schrieb:
Are the heating pipes fixed in place, or can they move with temperature changes?Thank you for the detailed answer! The pipes are embedded in the wall and floor, secured but not completely rigid since they are flexible pipes. So, slight movements due to expansion are possible, which could be another factor causing stress on the floor slab.
Therefore, I’m leaning towards adding an underlay. Are there any recommendations for the best material to use under KALLAX? I don’t want anything too thick, so the shelf remains stable, but it should still effectively distribute the load and absorb some of the movement.
YANNICK69 schrieb:
Are there any recommendations on which material is best suited for this with KALLAX?For your situation, I recommend a 4-6 mm (0.16-0.24 inch) thick sheet made of plywood or hardwood. It is sturdy, easy to work with, and distributes the load very effectively.
Alternatively, rigid PVC sheets are also suitable, as they are temperature resistant and easy to clean. Additionally, they are moisture resistant and somewhat flexible, which can compensate for pipe movements.
Avoid very soft materials like felt as the sole element, as they do not distribute the load adequately. A combination of a hardwood board with anti-slip rubber underneath could meet your requirements well.
Important: Make sure the support covers the entire surface area of the heating pipe and that no point load rests directly on the pipe.
tra_nina schrieb:
A combination of hardwood board and non-slip rubber could meet your requirements well.Absolutely, and to make it look nice too, you can even treat the board with some varnish or wood oil. This way, it remains not only functional but also visually appealing.
If you want to be on the safe side, choose a slightly larger base that covers not just a single point but a bit more surface area—and hey, a little extra safety margin doesn't hurt 😉
Oh, and if you want to rearrange later: feel free to put some furniture glides underneath as well, so the shelf doesn’t scratch and the pipe protection setup is perfect! 😊
