ᐅ KALLAX can no longer support a heavy binder – how can it be reinforced?
Created on: 6 Nov 2019 09:37
lemegoHello everyone,
I have an issue with my IKEA KALLAX shelf: it can no longer support heavy binders, as the shelves visibly bend under the load. The stability is simply no longer adequate, even though the shelf still looks good and shows no visible damage.
Therefore, I am wondering: how can I reinforce my KALLAX shelf so that it can handle heavier binders permanently without sagging or getting damaged?
I am interested in both DIY solutions and effective reinforcements or additions to and inside the shelf.
Thank you in advance for your tips!
Hello lemego,
First of all, regarding the cause: KALLAX shelves are made of particleboard with a thin melamine coating, which generally only supports moderate weights. The boards are not designed for lateral loads from heavy binders, especially when they are tightly packed and fully loaded. This quickly leads to bending.
There are several possible approaches to reinforce them:
1. Strengthen the back panel: Often the thin back panel is responsible, as it provides little stability. Screwing on an additional plywood panel (at least 6 mm (1/4 inch) thick) as a back can significantly improve the cabinet’s stiffness.
2. Support the shelves additionally: You can screw small metal angle brackets (e.g., aluminum angles) under the shelves to prevent bending. The brackets should be installed on the inside and fixed to the side walls.
3. Install cross braces: Another option is to install cross braces running across every 2–3 compartments to make the entire cabinet more stable.
4. Use MDF instead of particleboard: If you plan to modify it, replacing the shelves with stronger MDF panels is recommended.
I would also like to know how many binders you want to store per compartment and whether the shelf is secured to the wall. Wall mounting also helps distribute the load.
Additionally, how much time and effort do you want to invest? Should it be a temporary solution or something permanently load-bearing?
Regards kulau
Regards kulau
Hey lemego,
great that you started this topic here! I totally know the problem – KALLAX shelves are really practical, but they often can’t handle heavy items very well 🙂
What helped me a lot was getting some small steel brackets that you simply screw under the shelves, and then secure the whole thing with extra screws into the side panels. Since then, the shelves have been holding up great, even with fully loaded binders!
I also fixed the shelf to the wall, which adds a good sense of security. I think this kind of reinforcement is really clever because it doesn’t take much effort but makes a big difference!!
Good luck with your renovations, you’ll definitely manage! 🙂
Hello lemego,
I completely understand your concern about the KALLAX shelves bending under the weight of heavy binders. Unfortunately, this is a known issue since IKEA designed KALLAX with a focus on aesthetics and space-saving rather than very high load capacity.
A common and practical solution is to reinforce the existing shelves by adding metal brackets underneath the board. These can be attached with small screws to the underside and effectively strengthen the shelf.
It is also important not to exceed the maximum load per shelf permanently (usually around 13-15 kg per shelf). If the binders are very heavy, I recommend reducing the number of binders per compartment or adding additional supports, such as wooden strips or small brackets, to the unit.
Attaching a solid wood panel as an extra shelf or as a load-distributing layer is also a good idea.
If you like, I can provide you with a step-by-step guide on how to reinforce the shelves properly.
BeAndrea
BeAndrea
kulau schrieb:
1. Reinforce the back panel: ... Attaching an additional plywood board (at least 6 mm thick) as a back panel can significantly improve the cabinet’s rigidity.This is a very important point. The KALLAX units primarily gain stability from the back panel.
Nils58 schrieb:
I got a few small steel brackets that are simply screwed under the shelves, and then the whole thing is further secured with additional screws into the side panels.These angle brackets under the shelves are also effective but require that the screws hold well in the particleboard – preferably with pre-drilled holes to avoid splitting.
Additionally, I recommend distributing the load across multiple compartments. When dealing with a large number of fully loaded binders, the shelving should not be viewed as a standalone element but should always include wall mounting and additional structural measures.
One more tip: If the shelves are used long-term, check whether the weight stresses the base panel of the entire unit and, if necessary, work with a more stable foundation.
flo56
