ᐅ KALLAX Magnetic Lock in Use – Is It Sufficient?
Created on: 27 Jan 2017 08:17
tra63
I am currently looking into how the KALLAX magnetic latch performs in everyday use. My question is: Is the KALLAX magnetic latch really sufficient in practice to keep doors securely closed at all times and prevent accidental opening? I have heard many positive things so far, but what matters most to me is how durable this latch is with frequent use, whether it holds well on somewhat heavier or fully loaded doors, and if it remains reliable over the long term.
I am particularly interested in real-world experiences involving challenging situations, such as households with children or frequent opening and closing when putting items in and out. If anyone has detailed long-term experience with this magnetic latch, I would appreciate a thorough assessment. Thanks in advance!
nepeo66
28 Jan 2017 08:19
In short: Magnetic catches are sufficient for lightly loaded doors.
Heavy doors or children require more mechanical resistance to counteract.
tra63
28 Jan 2017 09:30
FLONE41 schrieb:
Flexible child locks are used that can be easily operated from the outside but are more difficult for small children to open.
Thanks, interesting. Do you know how durable these are in long-term use? I don't want flimsy plastic locks that break after a few months.
giabau schrieb:
With children or pets, the magnet is often unintentionally overcome.
Are there magnetic additional locks that can be installed alongside? Like a double magnet for extra security.
giabau
28 Jan 2017 09:56
Adding magnetic auxiliary locks is feasible – there are so-called auxiliary magnets or magnetic bolts that provide stronger holding power. However, the installation should be carefully planned to avoid component conflicts or excessive complexity.
If you want enhanced protection, I would recommend the following sequence:
1. Check the door load and appearance
2. Choose appropriate magnetic reinforcements
3. Add mechanical locks that are easy to operate (such as hasp locks or sliding bolts)
Tip: For children, a combination of mechanical locks and magnetic closures usually works best. For durability, I recommend products with metal parts and quality certifications, avoiding cheap plastic components.
barge
28 Jan 2017 11:12
tra63 schrieb:
Are there perhaps magnetic auxiliary locks that can be installed alongside?
Yes, there are! I installed a small additional magnet lock on the opposite side. This provides double security. It works great and looks quite unobtrusive.
For the kids, an extra small twist lock on the inside also helps—they can’t easily open it. This combination is my secret tip 😉
It has been working reliably for over a year now without any major issues.
