ᐅ Loss of Structural Stability in KALLAX After Water Leak – Is It Salvageable?
Created on: 31 Oct 2019 08:37
Lulapra
Lulapra
31 Oct 2019 08:37
I have an IKEA KALLAX shelving unit that was damaged by a water leak. Water collected in the shelves for several hours, which apparently has significantly affected its stability. The shelves now appear swollen, and the entire piece of furniture no longer stands securely.
My question is: Are there ways to restore a KALLAX shelving unit to a stable condition after such water damage? Or is the material so vulnerable that saving it is unlikely?
I would like to know which methods or products have proven effective for drying or repairing swollen boards, and whether reassembling or reinforcing it makes sense.
Thanks for your advice!
flo56
31 Oct 2019 09:16
Lulapra schrieb:
Are there ways to restore a KALLAX shelf to a stable condition after water damage like this?
The KALLAX shelf is basically made of particleboard with a thin plastic or melamine coating. When it absorbs water, the boards swell significantly and lose their load-bearing capacity.
A complete restoration of stability is usually difficult, except in cases of superficial moisture that dries quickly.
Recommendation: disassemble the shelf, let the parts dry carefully and evenly, preferably at room temperature with good air circulation. If necessary, repair minor damage with edge banding or wood filler, and reinforce critical joints with screws.
In the long term, however, the shelf will lose strength, especially if the material has been permanently affected.
Juan31
31 Oct 2019 09:44
flo56 schrieb:
Disassemble the shelf and let the parts dry carefully and evenly, preferably at room temperature with good air circulation.
This is the most important step. Many people make the mistake of reassembling the damp parts or drying them quickly with artificial heat. This causes warping and cracks in the material.
Additionally, after drying, you can protect the edges with sealing varnish or wood glue to prevent future moisture damage.
If individual boards are severely warped, replacement is usually more cost-effective and reliable.
Lulapra
31 Oct 2019 10:05
Juan31 schrieb:
Additionally, after drying, the edges can be protected with sealing lacquer or wood glue
Thank you, that already sounds very helpful. Which products are particularly suitable for KALLAX panels? I assume the surface is coated with melamine and not traditional wood, right? Are there special wood adhesives that bond to melamine? Or would silicone sealants be more appropriate?
Also: Is it possible to sand down the swollen edges, or would that compromise stability?
Donar34
31 Oct 2019 11:21
Sanding is problematic: KALLAX particle boards have a thin melamine or film coating that protects the panels from moisture. Once this coating is damaged at the edges, even more moisture can penetrate.
If the edges are only slightly swollen, careful sanding may help, but only a small amount of material should be removed. Afterward, the edges should be well sealed, for example with a waterproof paint or specially coated edge banding.
Silicone sealants are not suitable, as they do not provide structural support and can detach over time.
Colby42
31 Oct 2019 12:34
Hey, I had exactly the same problem with my KALLAX after my aquarium overflowed!
I took the panels apart and left them to dry for several days at room temperature near a window. Then I refinished all the edges with a special edge banding from the hardware store, which looks great and really makes a difference!
Since then, the shelf has been solid and stable again – I’m really happy I didn’t have to throw it away. :-)
So, definitely take it apart, let it dry properly, and reseal the edges! This was a lifesaver for me!
