ᐅ Are there any clever tips for reinforcing KALLAX units after moving them?
Created on: 8 Aug 2021 10:37
nigikin
nigikin
8 Aug 2021 10:37
Are there any clever tips for reinforcing KALLAX after moving? I have often noticed that the shelves lose stability after being taken apart and reassembled, even when all parts are correctly installed. Especially when setting up the KALLAX in a new apartment or room, the structure seems less sturdy than before. Are there any practical suggestions beyond the standard instructions to make the shelving more durable and secure? I would appreciate any advice based on personal experience or professional knowledge!
sarGabriel
8 Aug 2021 10:51
I recommend completely loosening all screws and thoroughly cleaning the shelf before reassembling it. After that, secure all joints with a good wood glue for added stability; this will make the KALLAX sturdier.
GU-LAU60
8 Aug 2021 11:03
Additional brackets might help reinforce the corners. You can install these discreetly on the inside without affecting the design.
RonJarrett
8 Aug 2021 12:19
Stability issues usually arise from micro-movements at the joint connections after assembly. A common professional tip is to lightly coat the plug-in joints with wax lubricant or paraffin before fitting them together. This helps the parts fit more securely and reduces wear. Additionally, the connections can be reinforced with small nails provided with the kit, if any are left. Otherwise, flat wood connectors attached to the back panel and sides can significantly strengthen the structure.
nigikin
8 Aug 2021 12:44
RonJarrett schrieb:
Treat plug connections lightly with wax lubricant or paraffin before assembling
That sounds interesting. Where can you get such wax lubricant, and could I possibly try candle wax as well? Or is that not really recommended?
Are there any other aids besides wax protection to make the connections more secure without adding visible reinforcements on the outside?
roryvin
8 Aug 2021 13:12
Candle wax is basically possible but should be based on natural wax to prevent deposits or rubber-like residues from forming. Hardware stores often offer special furniture wax or shellac, which is better suited.
Additionally, self-adhesive foam pads or small felt strips can help minimize internal movement, especially between the back panel and side panels of a shelf.
For reinforcement without visible external elements, gel-based wood glues are also suitable, as they remain transparent and flexible when cured.
