ᐅ KALLAX in a Vacation Home – Can It Withstand Temperature Fluctuations?
Created on: 27 May 2016 09:42
KENNETHUS
KENNETHUS
27 May 2016 09:42
I am planning to equip my holiday home with an IKEA KALLAX shelf unit next summer, mainly for storage. However, the house is located in a place where it gets very cold in winter, sometimes below -10 degrees Celsius (14°F), and can get quite warm in summer, often over 30 degrees Celsius (86°F). My question is: can the KALLAX shelf withstand these significant temperature fluctuations without damage? Specifically, I am interested in whether the material becomes brittle in cold or deforms in heat, and whether the joints or coating might be affected. I would prefer not to find cracks or warping after just one season.
Does anyone have experience with using KALLAX in such conditions, possibly even directly in an unheated holiday home? Any information regarding storage in damp or cold environments would also be helpful.
Thank you in advance for your assessments!
Lance
27 May 2016 11:37
Hello KENNETHUS,
Your question is very relevant, especially since KALLAX is made from a type of particleboard with a melamine coating, which is not designed to withstand extreme temperature or humidity fluctuations.
The material itself can become brittle in cold temperatures because the resin binders in the coating lose elasticity when cold. This increases the risk of small cracks, particularly when additional mechanical stress occurs.
In heat, depending on the humidity, deformation can occur since particleboard tends to expand or contract easily. Another point is that the shelf can swell when exposed to moisture, which can happen in vacation homes due to condensation or insufficient ventilation.
I use KALLAX myself in my garden shed, which experiences similar temperature conditions, and from my experience, the shelves show slight deformation after about three years of use without additional treatment. The joints with dowels and metal fasteners generally hold well, though I recommend not placing the shelf directly on a cold floor but using an insulating base.
One more question: How exactly is the vacation home constructed? Is it insulated? Is there heating or at least some air circulation? This significantly affects durability.
Lance
KarTristan
27 May 2016 13:04
I agree with Lance but would like to add: KALLAX is designed for living spaces and similar environments.
Lance schrieb:
In case of moisture, which can occur in holiday homes due to condensation or insufficient ventilation, it can swell.
That is exactly the main problem. If you place the shelving unit in an unheated area, cold nights followed by warm days can cause condensation on the surface. This seriously damages the boards.
My advice would be to use the KALLAX in a heated or at least well-ventilated room, or to treat it on site with additional protective measures (e.g., clear lacquer coating, water-repellent film). Mounting it on the wall can also add stability and prevent contact with damp floors.
An alternative would be to use materials with higher moisture resistance if the conditions cannot be improved.
Evamo
27 May 2016 15:21
KALLAX is not designed for extreme temperature variations.
If you still want to use it, place it in a heated or well-ventilated room. Otherwise, it may warp or crack.
pautanner
28 May 2016 08:53
Hello everyone! 🙂
I set up my KALLAX units last year in our small weekend cabin – the temperatures here aren’t quite that extreme, but the shelves were still placed in an unheated room. Sure, there were a few minor dents and slight warping after one winter. But for handling a bit of clutter in a holiday home, it’s really fine.
KENNETHUS schrieb:
Does the KALLAX shelf withstand significant temperature fluctuations without damage?
In short: If you take it easy and don’t expose the shelves directly to moisture or severe frost, they hold up quite well. Maybe air the room occasionally and avoid putting too much weight on individual compartments when loading them 😉
In my opinion, for the price, there’s no reason not to use it in a holiday home as long as you keep an eye on it. And hey, if things do get worse, IKEA often offers goodwill replacements. Good luck!
