ᐅ KALLAX furniture casters get stuck on carpet – any alternatives?
Created on: 16 Sep 2024 08:47
malcolmHello everyone,
Some time ago, I fitted an IKEA KALLAX shelving unit with caster wheels to make it easier to move around my apartment. Unfortunately, the wheels tend to jam quite quickly when I roll the furniture over my carpet. While the wheels work fine rolling over the carpet without load, once weight is applied—especially when the shelf is fully loaded—they hardly roll or get completely stuck.
My question for you: Are there any proven alternatives to standard caster wheels that perform better on carpet? Possibly different types of wheels, tips, or modification options? I’m looking for a solution that keeps my KALLAX unit mobile without constantly blocked wheels.
Thanks in advance for any advice and experiences you can share!
Hello malcolm,
I had a similar issue with KALLAX casters on carpet, so here is a brief summary with possible alternatives:
1. Wider casters: Standard casters are often too small and can get caught easily in carpet. Wider wheels distribute the weight better and roll more smoothly.
2. Casters with rubber rings: Hard plastic wheels tend to catch more, while casters with soft rubber treads glide more gently on carpet.
3. Casters with ball bearings: High-quality ball bearing wheels roll much easier under load.
4. Furniture glides as an alternative: Instead of casters, use flat glides underneath that you can move manually when wheels aren’t necessary.
5. Buy caster bases with larger wheels and attach them to the KALLAX. There are also special casters for carpet available from hardware stores.
Important: The mounting distance of the casters and the weight capacity should match the size of your KALLAX.
Tip: Before purchasing, test how the casters perform on your carpet, as different carpet thicknesses and textures have different requirements.
In summary: Wider, rubber-treaded, and high-quality casters should be the first option.
Good luck!
Good luck!
warrenka5716 Sep 2024 10:03fredle schrieb:
Wider wheels distribute weight better and roll more smoothly.I noticed that too, thanks for the tip!
I had one of my shelves on a thick carpet and at first, I thought it would always get stuck when I tried to move it. It really made me nervous, especially during rearrangements at home. You constantly have to pull and push, which is very tiring.
That’s why I think it’s great to pay closer attention to the wheels here, especially since it’s about comfort.
Malcolm, could you try to remember how thick your carpet is exactly? That would help as a reference.
warrenka57 schrieb:
Malcolm, try to remember exactly how thick your carpet is?Good point! My carpet is about 14 mm (0.55 inches) thick, relatively tightly woven, a standard textile carpet—not a flokati or similarly fluffy type.
I assume the rollers catch mainly because they are quite small and made entirely of hard plastic. This really frustrates me, as it turns moving the item into a small task that I actually want to avoid.
For a carpet approximately 14 mm (0.55 inches) thick, wheels with a larger diameter (40-50 mm (1.6-2 inches)) and soft rubber tires are recommended. The softer rolling surface better adapts to the carpet texture without catching.
Alternatively, so-called furniture floor wheels designed specifically for soft surfaces can be used. These wheels are usually slightly wider and have a flattened cross-section to prevent sinking into the carpet.
Another consideration: if the wheels are needed only occasionally, fixed furniture glides might help, protecting the shelf and limiting moving to short lifts.
Overall, the focus should always be on details such as wheel diameter, material, and the carpet structure.
