ᐅ KALLAX furniture casters get stuck on carpet – any alternatives?
Created on: 16 Sep 2024 08:47
malcolm
Some time ago, I fitted an IKEA KALLAX shelving unit with caster wheels to make it easier to move around my apartment. Unfortunately, the wheels tend to jam quite quickly when I roll the furniture over my carpet. While the wheels work fine rolling over the carpet without load, once weight is applied—especially when the shelf is fully loaded—they hardly roll or get completely stuck.
My question for you: Are there any proven alternatives to standard caster wheels that perform better on carpet? Possibly different types of wheels, tips, or modification options? I’m looking for a solution that keeps my KALLAX unit mobile without constantly blocked wheels.
Thanks in advance for any advice and experiences you can share!
To determine the best casters for carpeted floors on KALLAX shelving units, a technical assessment is recommended:
- Wheel diameter: At least 40 mm (1.6 inches), preferably 50 mm (2 inches) or larger.
- Material: Thermoplastic elastomer (TPE) or rubber, to combine grip and smooth rolling.
- Load capacity: Depending on the weight of the shelving unit, the casters should support at least 50 kg (110 lbs) per wheel.
- Attachment: Check if the existing mounting points on the KALLAX are compatible or if adapters are needed.
From a professional perspective, combination casters with roller bearing technology are the most efficient.
Additionally, a carpet underlay (e.g., a thin, rigid plastic sheet beneath the casters) could help reduce slipping. This would be an extra measure if casters specifically designed for carpet are not available.
Fitigu schrieb:
Additionally, a carpet underlay (e.g., a thin, rigid plastic sheet under the wheels) could make sliding easier.That is actually an important tip. I would even suggest experimenting with a thin plexiglass or MDF board under the shelf to distribute the load on the carpet and prevent the small wheels from sinking in.
Although this might slightly reduce mobility, it is a good balance between stability and ease of movement when something needs to be relocated quickly.
Good wheels are fundamental, and an underlay can make all the difference.
