ᐅ KALLAX for Model Railways – Is the Structure Strong Enough to Support the Load?
Created on: 13 May 2019 18:17
Z
Zar-lis
Z
Zar-lis
13 May 2019 18:17
I am planning to build a sturdy frame for my model railway and am considering using the IKEA KALLAX shelving units as a base. My specific question to the community is:
Can the KALLAX unit – especially the specially designed compartments and the thin back panels – support the weight of model railway modules, some of which are quite heavy, over a long period without warping or damage?
I understand that KALLAX was not originally designed for such loads, but since I find the shelving practical and versatile, I am thinking about simply fastening the units together and possibly reinforcing them further.
Has anyone had experience using KALLAX as a base for model railway setups? I am particularly interested in whether the shelves or side panels bend under the weight of heavy locomotives, tracks, and scenic infrastructure.
I look forward to your insights and tips on how to reinforce the KALLAX unit if necessary.
refinar
14 May 2019 09:44
Hello Zar-lis,
your question about using the KALLAX shelving unit as a base for model railways is very interesting and relevant to many model builders looking for a sturdy yet cost-effective foundation.
I have set up several layouts on KALLAX myself and can share my experience:
1. Load capacity of the shelves:
The individual compartments of KALLAX are generally designed for a uniform load of about 13-15 kg per compartment. This applies to typical furniture loads, not necessarily to concentrated, point loads such as heavy modules with track systems.
2. Weak points:
The shelf bottom can bend under excessive weight, especially if the load is centered and not evenly distributed. The thin back panel provides some lateral stability against twisting but does not contribute to load-bearing capacity.
3. Reinforcements are recommended:
- Adding extra wooden boards under the shelves for support
- Connecting the individual KALLAX units with screws and metal brackets
- Securing the shelves to the wall to prevent tipping
4. It is also important to pay attention to the overall load and weight of the models. Very heavy landscape structures or modular segments may need to be placed on more stable foundations or supported with additional cross braces.
In summary: KALLAX is basically a good and affordable starting point if you add proper reinforcements and carefully distribute the weight.
If you have questions about specific reinforcement options, I am happy to provide more detailed advice.
LUSAR
14 May 2019 16:22
refinar schrieb:
The individual compartments of KALLAX are generally designed for a uniform load of approximately 13–15 kg per compartment.
That is correct; these figures are based on manufacturer specifications and tests under standardized conditions.
From a technical perspective, it should be noted that although the maximum load capacity of the shelves is specified, this can be significantly reduced by point loads. A model railway with a heavy base and tracks creates additional local stress points.
Zar-lis schrieb:
Whether the shelves or side panels bend under the load of heavy locomotives, tracks, and landscape infrastructure.
Here, the back panel proves to be non-load-bearing.
Conclusion:
- The KALLAX construction is primarily designed for evenly distributed loads, not for point heavy loads.
- Reinforcements, especially of the shelves using plywood or metal plates, are recommended.
- For larger setups or longer track lengths using KALLAX, additional cross braces or a supporting substructure should be installed.
A combination of IKEA KALLAX and additional wooden elements for increased stability is therefore the most practical solution within a limited budget.
marcosku52
15 May 2019 11:34
Hey everyone,
I’d like to add a more casual perspective to this :-)
I also built my small Märklin setup on a KALLAX unit – obviously, these pieces aren’t designed for heavy loads, but with a few tricks, they can last quite a while!
Important points:
- Make sure to screw the shelves together properly. The snap-fit connection alone is quite stable, but if you just set it up without screws, it will eventually wobble.
- I added simple slats under the shelves to better distribute the pressure on the shelf boards.
- When attaching tracks and modules, ensure the weight is distributed evenly. It’s best to initially set everything up as a test and check for pressure points in the middle.
What I also learned: the KALLAX shelf is very flexible – if one section feels a bit weak, you can always reinforce the surface later with thin wood or acrylic (plexiglass) or add a support beam.
So: it wouldn’t be my first choice for a massive layout, but it’s definitely practical for small to medium home scales.
Good luck with your setup 🙂
