ᐅ KALLAX damaged after falling from attic – is it still repairable?
Created on: 8 Feb 2019 07:43
julien_fiJ
julien_fi8 Feb 2019 07:43Hello everyone,
I have a rather unusual problem: Recently, my IKEA KALLAX shelving unit fell over from my attic – it was fully assembled and likely toppled due to an unfortunate combination of circumstances. It was damaged in several places, mainly some of the wooden panels are cracked or split, the back panel has come loose, and a few shelves are now crooked.
The shelving unit is about 2 years old and was actually in great condition apart from this accident. I am now wondering whether it even makes sense to repair it or if the damage is too severe.
Is it possible to salvage a KALLAX after such a fall, or is it better to just replace it? Are there any tricks to restoring its stability? What materials or tools would be helpful? I am reasonably handy but don’t have experience with repairs of this kind.
I would appreciate any assessment or advice, especially from people who have repaired something like this themselves or are familiar with the product.
julien_fi schrieb:
Is it possible to somehow save a KALLAX after a fall like this, or is it better to just buy a new one?Honestly, if you ask me, a KALLAX is like a rocking horse – hardly repairable once it’s seriously damaged. The thin particleboard and simple construction aren’t really designed to handle heavy loads, let alone a fall from an attic.
The problem is that the bonding usually comes apart with this material, causing the whole structure to lose its stability. Repairs often only last a short time and never fully restore the original strength.
So why bother repairing? A new unit isn’t expensive, and at least then you have something that will stand securely again.
That said – I’m looking forward to hearing opposing views 😉
BERONAR schrieb:
that the bond in the material usually fails and the stability of the entire structure collapses.I can generally confirm that. KALLAX is mostly made from particleboard, which is not very durable under heavy load or impact. However, I wouldn’t immediately recommend buying a new one.
It is important to carefully examine which parts are actually damaged: Are only the surfaces affected, or are any load-bearing components broken?
If there are cracks or breaks in the side panels, these could be reinforced with suitable wood glue and possibly additional battens. The back panel, often just a thin board nailed in place, can be reattached – replacing it with a thicker back panel made of plywood or MDF and securing it with screws can significantly improve stability.
Shelves that aren’t broken might be supported underneath with metal brackets or glued back into shape.
You could, for example, use Ponal wood glue and reinforce with small wooden dowels or narrow brackets. A good clamp is also helpful for pressing glued joints together.
Overall, if done carefully, it is definitely possible to repair a piece of furniture like this. However, it requires some effort. If you have basic DIY skills, this is a viable option.
BERONAR schrieb:
The thin particle boards and simple construction are not really designed for heavy loads.That’s not entirely true in general. KALLAX is not primarily designed to withstand impacts like a fall, but it is quite sturdy for normal use. The main issue is usually less the particle board itself and more the joinery method: dowels and glued joints can be damaged easily.
naudan schrieb:
If there are cracks or breaks in the side panels, they could be stabilized with suitable wood glues and possibly additional wooden strips.I consider this the most sensible approach, especially if you have some experience. Buying a completely new shelf shouldn’t be the first option, as it has a high environmental impact and is often unnecessary if repairs are possible.
I recommend taking the shelf completely apart before repair, replacing damaged parts (perhaps with matching wood sections from a hardware store), and then reassembling it with wood glue and screws. Stability can also be improved with extra reinforcements like brackets or metal fasteners.
Even a beginner can manage this with some patience, and it saves money.
julien_fi schrieb:
whether a repair even makes sense or if the damage is too severe.Well, first of all: that sounds like quite a mess! But hey, you don’t have to give up right away – at least not without trying.
As naudan and difepeo already mentioned, a repair is definitely possible for a box like that, especially if you enjoy the process and don’t require perfect results. Wood glue, some clever bracket solutions, maybe a bit of paint to cover it up – and voilà, your (almost) new KALLAX buddy.
And if some flaws still show: a bit of chaos is part of the deal. 🙂
PS: Always keep in mind – IKEA shelves are not made of solid wood, so no need to panic over dents. Good luck with the repair!
