ᐅ Kallax baseboards damaged during moving – any repair tips?
Created on: 5 Mar 2018 14:03
leomin
leomin
5 Mar 2018 14:03
I recently bought a Kallax shelf unit from IKEA and had to move it around several times to find the perfect spot. During this, I noticed that the white baseboards at the bottom edge of the shelf have chipped and been damaged in several places. This is frustrating, of course, as it not only looks unattractive but also reduces the baseboards’ protective function against moisture.
Has anyone had experience repairing such damage to the Kallax baseboards? I’m mainly referring to small dents, chipped areas, or scratches. Are there suitable paints, fillers, or even special repair kits that work well? Or perhaps practical tips on how to prevent further damage when moving the unit in the future?
I look forward to your advice and repair experiences!
koanbar
5 Mar 2018 14:29
For chipped areas, I always use wood filler, then sand it smooth and touch up with white paint. Acrylic paint should adhere well to Kallax.
To protect the surface while moving, a felt pad under the feet is helpful.
U
Ulrichta
5 Mar 2018 15:47
Hello leomin,
I can understand your situation well. The Kallax baseboards are made of coated wood-based material, which is unfortunately quite sensitive to impacts and scratches. The first important step is to clean the damaged area thoroughly and lightly roughen it so that filler or paint adheres better.
I would recommend using a fine-grain wood filler that can be easily applied with a small spatula. After it dries, sand carefully to create a smooth surface. Then you can repaint the spot with fast-drying acrylic paint in white.
As an alternative, if you don’t want to use filler, there are also special repair pens or touch-up paint pens that can be applied locally. However, these are usually only suitable for smaller scratches.
To prevent further damage: attach felt pads to the bottom of the shelf or always lift the shelf when moving it to minimize contact with the floor. I hope this helps you! 🙂
LANICOLE
6 Mar 2018 09:11
Hello leomin,
here is a more detailed explanation of how I repaired damaged Kallax baseboards – this might be helpful for you:
1. Preparation: First, gently roughen the affected area with fine sandpaper (grit 180 to 220). This prepares the surface well for the filler.
2. Filling: Use a high-quality, white pigmented wood or multi-purpose filler that adheres well and is easy to sand. Apply it thinly and try to shape the contour as accurately as possible.
3. Sanding: After it is completely dry, sand the surface smooth with fine sandpaper (grit 240 to 320) so that the transition to the original surface is no longer visible.
4. Painting: It’s best to use acrylic or water-based paint in matching pure white. Several thin coats are better than one thick layer. Allow each layer to dry thoroughly in between.
5. Aftercare: To prevent future damage, I recommend attaching furniture gliders or felt pads to the back of the baseboards. This makes it easier to move the shelving unit without damaging the paint or wood.
A common mistake I often see is painting over without filling first – this rarely provides a lasting repair on chipped material.
I hope this short guide helps you! Feel free to ask if you have any questions.
leomin
7 Mar 2018 17:24
LANICOLE schrieb:
A common mistake I often see is painting over without filling first – this rarely works well or lasts on chipped surfaces.
Thank you very much for the detailed response, that makes sense! I had actually only painted over after lightly sanding the shelf, but didn’t fill it. That probably explains why the blemishes kept showing through.
I will try using filler. Are there any recommendations on which products have worked particularly well for you? And how is the texture after the repair – does the area become very rough or uneven?
Also, one more question: Are there any good alternatives to paint for outdoor use if I leave the shelf on the balcony during winter? I want to avoid moisture collecting under the repaired spot.
U
Ulrichta
8 Mar 2018 06:53
leomin schrieb:
Are there any recommendations for products that have proven to be particularly durable with you?
I often use products from brands like "Mannol" or "Ponal" for wood filler; they are durable and easy to sand.
With sufficient sanding, the repaired area becomes very smooth and hardly noticeable; multiple sanding passes using fine-grit sandpaper are important.
leomin schrieb:
Are there practical alternatives to varnish for outdoor use, in case I leave the shelf on the balcony during winter?
Since Kallax and similar furniture are made from wood-based materials, I generally advise against leaving them outside permanently. If you do, a weather-resistant, matte acrylic paint with UV protection might help, but it’s better to apply a sealant beforehand.
Otherwise, repair kits for marine varnish or special PU clear coats are durable but complicated to use and usually oversized for indoor furniture.
I hope this gives you some helpful guidance 🙂
