ᐅ KALLAX as a Hanging Shelf for Plants – What Should I Consider?
Created on: 11 Nov 2021 18:27
Anisneo
Anisneo
11 Nov 2021 18:27
I am considering using a KALLAX shelf as a hanging shelf for plants to add more greenery accents to my living room while saving space. My goal is to hang the shelf so that it is stable and both the plants and the wood are protected sustainably. Does anyone have experience with what I should specifically pay attention to when hanging the KALLAX shelf and placing plants on it? I am thinking about factors like load capacity, moisture damage from watering, wall mounting, and how to prevent waterlogging.
I would also be interested to know which hanging methods and materials are recommended to ensure the shelf holds securely while protecting the wall. Could you also provide tips on whether the KALLAX material should be modified, for example with a protective coating or similar?
I look forward to your opinions and experiences!
TEBILO
11 Nov 2021 21:16
Hello Anisneo,
First of all, this is a very good and well-defined topic! Using the KALLAX shelf as a hanging shelf for plants is definitely possible, but there are some important points to consider to avoid any problems:
1. Load capacity and mounting: The KALLAX shelf itself is not designed for hanging loads, as it was originally intended as a freestanding or modular shelf. Therefore, wall mounting is crucial. Be sure to use heavy-duty anchors and screws with appropriate wall plugs that can support the weight of the plants plus substrate and water reserve. A thick beech wood frame, for example, can bear more weight than the particleboard material that KALLAX is usually made from.
2. Protection against moisture: The biggest risk is water seeping from plant saucers or directly from the pots into the shelf, causing the material to swell. I recommend sealing all shelf surfaces with a waterproof coating such as marine varnish or a matte polyurethane sealant. Alternatively, precisely fitting saucers with plastic liners or silicone mats can help protect the wood.
3. Avoiding waterlogging: To prevent the plants from sitting in water—which puts unnecessary strain on the shelf—use either outer pots with water reservoirs or apply mechanical aquarium mats. Hanging versions, in particular, must not absorb excessive moisture.
4. Installation tips: Pay attention to the correct alignment of the back panel and additionally fasten braces or angle brackets inside the shelf to increase stability. You might also consider installing metal profiles to better distribute the weight.
One more question: Approximately how heavy are your plants, and how many do you plan to display on the shelf? This will help better assess the sizing.
I hope this helps you so far. Feel free to ask for more details.
KUDAISY
12 Nov 2021 09:43
Hello Anisneo,
I would like to summarize my suggestion in a structured way to give you a clear guide:
Introduction:
KALLAX shelves are suitable for various uses due to their modular design, including as plant shelves. However, KALLAX is mainly made of coated particleboard, which means it is sensitive to moisture.
Step 1: Choosing the right mounting hardware
- Use heavy-duty wall anchors suitable for your wall type (e.g., concrete or drywall)
- Drill carefully and precisely to avoid damaging the wall
Step 2: Protection against moisture
- Seal the inside of the shelf compartments with clear varnish or a water-repellent protective coating
- Place waterproof trays under the plant pots
Step 3: Determining the weight load
- Calculate the total weight including plant pots, soil, and water
- Include a safety margin of at least 20-30%
Step 4: Plant selection and care
- Choose plants with low water requirements or those that do not need constant waterlogging
- Use plants with drainage to prevent water accumulation
Summary:
The most important points are not to underestimate the load capacity and not to neglect wood protection. Also, regularly check for moisture buildup or any movement in the shelf.
TEBILO schrieb:
I recommend coating all shelf surfaces with a waterproof sealant such as marine varnish or a matte polyurethane finish.
I would also confirm this to extend the lifespan.
If you like, I can also provide you with a list of suitable protective treatments and specific plant species.
semuneo
12 Nov 2021 12:52
Anisneo schrieb:
Does anyone have experience with what I should specifically consider when mounting the KALLAX shelf and placing plants on it?
I think your question is very important because I recently had similar concerns myself. The main challenge for me was how to create a nice green wall solution without everything sagging or the plants suffering.
KUDAISY schrieb:
Choose plants with low water needs or those that don’t require permanent waterlogging
I completely agree – I initially had major problems with damp spots on the shelf and worries about odors. My advice: pick plants that you can keep healthy with minimal watering, such as succulents or certain types of ferns that are more tolerant.
I also attached small felt or rubber pads to the underside of the shelf to protect the wall and reduce vibration transfer.
For mounting: I screwed my KALLAX in at multiple points to distribute the load evenly – fixing it at only two points might put too much stress on the anchors over time. Maybe you could also consult a professional about the best type of wall plugs/anchors for your wall structure.
Overall, I would say it works really well if you pay close attention to load, moisture, and plant selection. It’s worth focusing on quality and safety here, even if it means investing more time and money than if you just use it as a freestanding shelf.
In my opinion, plant shelves are a lovely way to bring nature into your home – good luck with your project! 🙂
