ᐅ Is it worth repainting Ikea Hemnes furniture yourself?
Created on: 26 Oct 2022 19:42
Revolta
Revolta
26 Oct 2022 19:42
I am currently considering whether it is practically and economically worthwhile to repaint Ikea Hemnes furniture myself. The goal would be to give the pieces a more personalized look, possibly even out color variations, or hide minor signs of wear. At the same time, I am wondering if the effort in materials, time, and potentially needed craftsmanship is justified given the price of the Hemnes series, especially since Hemnes furniture is generally relatively affordable.
Has anyone here had experience with repainting these pieces? How does the durability of the new paint layer hold up? Are there common issues with the surface, for example related to the original coating used? Or might it be more sensible to consider alternatives that come pre-painted or are of higher quality? I look forward to your assessments, tips, and also recommendations on the best types of paint or preparation steps specifically for Hemnes boards.
LUISABEL
26 Oct 2022 21:07
Hello Revolta,
your question is relevant in many ways, especially because Hemnes furniture has some specific characteristics due to its lacquered surface:
- Ikea usually applies a clear coat on wood or MDF for Hemnes pieces, which is quite smooth and dense.
- Before repainting, thorough surface preparation is essential, usually by lightly sanding with fine-grit sandpaper (e.g., grit 220) to ensure the new paint layer adheres properly.
- Cheap or unsuitable paints quickly lead to chipping or uneven surfaces.
From my experience and research, repainting is especially worthwhile if you want a customized look and are willing to invest time. Economically, the effort is somewhat balanced by the fact that Hemnes is relatively affordable: if you cannot achieve a durable result, the effort often outweighs the benefit.
Water-based clear coats usually work best, as they adhere well and do not yellow. Alternatively, special furniture paints for wood can be used. Another recommendation: for pretreatment, use a degreaser or mild spirit to remove grease or dust residues.
Conclusion: Yes, it is worthwhile from an aesthetic perspective and with adequate craftsmanship, but less so if the goal is purely repair without increasing the furniture's value.
jodeo58
27 Oct 2022 07:36
Repainting only makes sense if you want to enhance the piece of furniture. Otherwise, it is better to buy a replacement.
rebufar
27 Oct 2022 12:51
LUISABEL schrieb:
From an economic perspective, the effort is less significant anyway because Hemnes is relatively inexpensive
I actually see it the other way around. Precisely because Hemnes furniture is affordable, you can afford to experiment freely with painting, trying out different colors or techniques without taking a big risk.
I find the whole idea that only expensive furniture should be painted quite limiting. Maybe that DIY spirit is exactly what makes it appealing. The real question should be: "How well can I carry out the project, and do I enjoy it?"
Durability depends heavily on the preparation. If you don’t have time for sanding and drying times, better to forget it. But for those who are interested, repainting is a great way to upgrade IKEA furniture.
You shouldn’t see it as too technical—furniture is also an expression of personality and creativity.
BOSULE
28 Oct 2022 09:18
Revolta schrieb:
Are there common issues with the surface, for example due to the coating used? Or would it perhaps be more advisable to opt for alternatives that come pre-painted or have a higher-quality finish?
The Hemnes series is generally well made but features a relatively thin layer of paint that is prone to scratching. Repainting requires careful and methodical work to
- avoid color deviations
- achieve a uniform, durable finish
Professional furniture restorers recommend using intermediate sanding and high-quality acrylic paints. With Hemnes, touch-ups are noticeable if the process is not carried out precisely.
If appearance is very important to you and the furniture will remain in the room long-term, it may be worthwhile to choose more expensive alternatives that are already finished with a higher-quality coating.
For occasional visual adjustments or refurbishments, repainting can be worthwhile if you are prepared for the effort and have the necessary equipment. For this, I can recommend the brand "Clou" for furniture paint.
