ᐅ Is it possible to equip Ikea Pax wardrobes with plexiglass doors?
Created on: 28 Aug 2020 19:23
reidtau
reidtau
28 Aug 2020 19:23
Hello everyone, I am considering fitting my Ikea Pax wardrobes with plexiglass doors instead of the original wooden or glass doors. My question is:
Is it generally possible to use plexiglass as a material for the doors of a Pax wardrobe without encountering major issues with fitting accuracy, stability, or mounting?
I am particularly interested in whether plexiglass meets the structural requirements, how easy or difficult the installation is, and whether special hinges or fittings are needed that differ from the standard mechanisms.
It would also be helpful if anyone could share from experience whether plexiglass resists scratches and discoloration over time or if it might age more quickly compared to the usual materials.
Thanks in advance for your insights and tips!
Gregory
28 Aug 2020 20:42
In principle, it is possible to equip Ikea Pax wardrobes with plexiglass doors, but there are several important points to consider:
- Plexiglass is lighter than glass but stiffer than wood, which can affect the hinges and fittings. The standard hinges for Pax doors are designed for wood or glass, so it is necessary to check whether they are suitable for plexiglass or if alternative hinges are needed.
- Fit is crucial: plexiglass must be cut precisely, as it is less flexible to adjust or trim than wood.
- Plexiglass tends to scratch more easily than tempered glass. There are special protective films or hardened versions that improve scratch resistance, which should be taken into account.
- Fastenings should have sturdy attachment points, as plexiglass has different load characteristics (brittle fracture versus fracture toughness) compared to wood.
In short, it is feasible but requires additional effort in material preparation and installation.
kibutar
29 Aug 2020 07:51
Gregory schrieb:
Fit is crucial: acrylic glass must be cut precisely, as it is less flexible for adjustments compared to wood.
This is an important point. I would add that the material thickness of the acrylic glass is essential. For doors that need to offer sufficient stability, I recommend at least 4-6 mm (0.16-0.24 inches). Thinner material can easily bend or break.
Another technical aspect is the mounting of the hinges. Standard hinges like Pax are designed for wood, so you either need to make special adapters yourself or use hinges with through screws suitable for acrylic glass—otherwise, you risk stress cracks.
Also, the cut edges of acrylic glass are usually somewhat rough right after cutting and should definitely be finely sanded and deburred to avoid fracture points.
Regarding scratch sensitivity: there are so-called "anti-scratch" coatings, but these are often applied as films that need to be renewed regularly if you want to keep the surface flawless over time.
I would also be interested to know exactly what your goal is: Should the acrylic glass be transparent, frosted, or colored? And how much weight do the doors need to support (e.g., mirror panels, handle profiles)?
These details are crucial for the final recommendation.
REPITAR
30 Aug 2020 10:17
kibutar schrieb:
I’m curious about your exact goal: Do you want the acrylic glass to be clear, frosted, or colored?
Something to consider for reidtau:
If you really want to use acrylic glass, I recommend following these steps:
- Selection: First decide whether you want clear, frosted, or colored acrylic glass. Each type has different properties and visual effects.
- Cutting: Ideally, have the acrylic glass cut by a professional company or a well-equipped workshop. It is difficult to fix inaccuracies in the material afterwards.
- Edge finishing: After cutting, edges should be deburred and carefully polished to avoid stress cracks.
- Fastening: Use appropriate fasteners with large washers to evenly distribute the load. Screws without large pressure points help reduce tension.
- Installation: Always start with a trial assembly to check whether the weight and hinges work well together. Acrylic glass can crack if there is too much tension.
- Maintenance: Clean acrylic glass only with special plastic cleaners and soft cloths to avoid scratches.
In summary: Acrylic glass is a feasible alternative for Pax units if these points are followed. The effort is higher than with standard wooden doors, but you get a modern look in return.
