ᐅ Is a split air conditioning system sufficient for cooling three rooms?
Created on: 6 Mar 2024 10:24
3
30156030Hello everyone,
we recently installed a photovoltaic system on the roof of our older house (built in 1959). This system is intended not only to reduce our electricity consumption but also to cost-effectively power other electrical devices. Specifically, I am interested in an air conditioning system for our upper floor. During hot summer nights, temperatures sometimes reach 27–29°C (81–84°F), making it almost unbearable to sleep. My attempts to use portable air conditioners (monoblocks) have not been very successful. I was already aware that such a monoblock is not an ideal solution. That is why I now want to install a split air conditioning system.
Currently, I am researching how many indoor units I will need. My plan is as follows:
I would install one air conditioning unit in the hallway, hoping that if the doors to the bedrooms and both children’s rooms remain open and the unit runs all day (when there is enough sunlight), the rooms will be sufficiently cooled in the evening and at night.
What do you think? Will this plan work, or should I actually install an air conditioning unit in all three rooms?
nordanney6 Mar 2024 11:16Nida35a schrieb:
Close the door to the staircase, otherwise the cold air will flow downwards.Or maybe size it large enough so that the cold air can also move downwards if needed.P
Pitiglianio7 Mar 2024 10:37In our previous apartment, we had an 18k BTU split air conditioner. It was able to cool the entire apartment with the doors open. Approximately 75m² (800 sq ft). In your case, be sure to close the door to the staircase leading down, because cold air is heavier and will mostly "fall" down the stairs.
