I want to insulate the ceiling of the top floor of our house (built in 1986).
The attic will not be used as living space in the future, nor for storage. At most, you might need access to the satellite dish or the chimney. There are no roof windows.
A brief description of the situation:
The roof has insulation between the rafters – you can practically see the reflective silver backing of the insulation. To provide stability to the roof insulation, wooden battens have been attached to the rafters at intervals of about 0.5 m (20 inches).
From inside the living space, the ceiling layers are as follows: drywall, double cross battens, vapor barrier, light insulation, wooden beams on the attic floor.
I now want to lay insulation boards or insulation wool on the attic floor. Is there any reason not to do this? Should I lay a foil on the floor first? In a video by Isover, it is shown that a foil is laid under the insulation wool, which must be installed airtight in the attic.
Or does the vapor barrier in my ceiling replace this foil?
Thank you very much for your help.
Uwe
Uwe
Hello Musketier,
That’s exactly what I’m aiming at. So you also think I could skip a second vapor barrier? That actually sounds reasonable and would simplify my plan.
I was planning to simply roll out mineral wool insulation in two layers, with the second layer laid crosswise to the first.
Uwe
Uwe
From a purely logical perspective, a vapor barrier in that location would not only make no sense but would actually be counterproductive, as it could lead to moisture being trapped between the insulation layers. However, this is just a layperson’s opinion.
Since you have also insulated the roof, you do not have a traditional cold roof. The question is how the temperature conditions will develop in the attic.
