ᐅ Installation of a UniFi Network (UCK, USG, AP-AC-Lite)
Created on: 20 Dec 2020 21:54
Crossy
Crossy
20 Dec 2020 21:54
We moved into our new house three weeks ago. In previous apartments, we always used just one router, which is about the limit of my networking knowledge.
To improve the network in the house, and partly inspired by posts in this forum, I decided to set up a Unifi network. My setup looks like this:
- Draytek 165 as modem
- TP-Link TL-SG1016PE 16-Port Gigabit Desktop PoE Smart Switch
- Unifi Security Gateway
- Unifi Cloud Key
- 2 Access Point AC-Lite units
After some trial and error, the internet is now working and both access points are functioning. However, the two access points do not appear in the Unifi network. Under "Devices," only the USG is shown:
UniFi Network Dashboard in dark mode with Internet, switches, access points, and Wi-Fi.
White UniFi USG router gateway with multiple Ethernet ports on dark UniFi Network Dashboard.
Both access points are visible in the Discovery Tool:
Screenshot of Ubiquiti Device Discovery Tool list showing three devices, host addresses, and status.
What do I need to do to have the two access points adopted into the network?
Thanks in advance for all the answers 🙂
Good luck
Crossy
rick201820 Dec 2020 22:34
Unfortunately, you probably didn’t look into this thoroughly. The Lite model is quite slow.
Now they are here. You can still replace them later.
You need to go to action and then adopt in the Discovery Tool. This should also work in the controller.
Did you set up the APs as standalone? Otherwise, they shouldn’t be broadcasting any SSID.
In the worst case, reset them and adopt them in the controller. Set up user group(s), network(s), Wi-Fi(s) ....
Crossy
20 Dec 2020 22:45
I chose the Lite model because it is smaller and, as far as I can tell, its performance should be sufficient for us. But as you said, it can always be replaced later.
I probably set it up as a standalone device. When I click on action in the Discovery Tool, I can select "Set Inform," "Locate," "Reboot," "Restore to Factory Default," and "Upgrade"; there is no option for adopt.
Does that mean only a reset is possible?
UniFi AP-AC-Lite Status Display in the Living Room
rick201820 Dec 2020 22:48
Restore to factory defaults. Then give them some time.
After that, they will appear under Devices in the controller. Click on adopt...
It takes about 10 minutes.
Connect the computer via cable since the Wi-Fi will be down for that long.
Crossy
20 Dec 2020 23:23
It worked. Thank you very much!
