ᐅ Installing flush-mounted electrical boxes: recessed or with spacers
Created on: 2 Jan 2019 19:42
Gerd&Jolanthe
I have a question.
I am currently installing the flush-mount electrical boxes in my shell construction.
If I am going to apply 1cm (0.4 inches) of plaster, how should I position the electrical boxes?
Should they be flush with the raw wall, or should they protrude by 1cm (0.4 inches) since the plaster will be added later?
Thank you very much.
Regards, Gerd
I have a question.
Regards, Gerd
Gartenfreund3 Jan 2019 06:28Flush-mounted switch boxes as well as flush-mounted junction boxes are always set slightly recessed so that after plastering, the boxes align as closely as possible with the plaster surface.
Switches and sockets belong inside the flush-mounted box, not mounted directly onto the plaster.
Instead of the cover suggested here, the traditional method of stuffing crumpled newspapers into the boxes can also be used. Even if the boxes are hidden beneath the plaster, they can still be detected through the plaster—unless the plaster is applied very thickly.
