kiki_295131 Dec 2011 14:41Hello, can someone help me? I bought a pharmacist’s cabinet. The panel is supposedly the correct one. However, there are also pre-drilled holes for hinges. But the bottom drawer must be attached exactly there. Should I drill into the plastic cover of the wrong hole? Will that hold the drawer securely in the long term?
I’m stuck and didn’t really want to spend the holidays on a construction site.
I look forward to an enlightening answer and otherwise wish you a happy New Year!
kiki_2951
kiki_2951
Nayla_106831 Dec 2011 19:11Hi,
exactly, you HAVE to drill into the cover, and yes, it holds. Just follow the instructions calmly and carefully, and it will work out. 😎
Enjoy your kitchen and have a great start to the new year
NfU
Na.
NfU
Na.
IKEA-Experte1 Jan 2012 10:15Drilling? The plastic cap has a groove where the screw bites in, right, or is something else meant?
Elvis_12203 Jan 2012 13:26Nayla meant that you can drill precisely according to the template directly into the plastic cover of the hinge recess. Even if it doesn’t seem stable at first glance – it holds!
As Nayla said – work methodically following the instructions and template – then it will work out.
sande_38323 Jan 2012 16:23Hello!
I have exactly this problem with this cabinet model. But what do you mean by template? Which template are you referring to? I have been looking for a long time and haven’t found one!
Regards, sande_3832
Regards, sande_3832
