ᐅ Removing stains from IKEA Malm nightstand – best method?
Created on: 23 Sep 2020 08:43
Abelkeo
Abelkeo
23 Sep 2020 08:43
Good morning everyone,
I have a small problem with my IKEA Malm bedside table. Unfortunately, stubborn stains have settled on it that I couldn’t remove despite simple cleaning. I’m mainly thinking of water marks and slight discolorations that have developed over time.
My specific question is: What methods or home remedies are most effective for reliably removing stains from the surface of an IKEA Malm bedside table without damaging the surface or finish? Are there any special cleaning products you would recommend, or perhaps tips that IKEA itself or experienced users suggest?
Thanks in advance for your tips and experiences!
dijan
23 Sep 2020 09:11
Abelkeo schrieb:
What methods or home remedies are most effective for reliably removing stains from the surface of an IKEA Malm nightstand without damaging the surface or finish?
Hey Abelkeo! 🙂
I recently had the same issue with my Malm and found that a mixture of warm water and a little dish soap works really well. Just wipe it with a soft cloth and avoid making it too wet, otherwise the wood might swell.
For stubborn stains, a bit of toothpaste (not the gel type, but the white kind) often helps—apply gently, let it sit for a short time, and then wipe off carefully. It’s important not to rub too hard to protect the surface.
Also, be cautious with harsh cleaners, as they can quickly damage the veneer.
Hopefully, your nightstand will look great again soon! 😉
TANBLA
23 Sep 2020 09:18
I recommend using a simple vinegar solution (1:1 with water). Wipe with a microfiber cloth, but do not leave it wet. Stains usually come off.
naujon
23 Sep 2020 12:04
to take a closer look at the topic, here is a short guide on removing stains from the IKEA Malm nightstand:
1. Preparation: Lightly dust the surface with a dry cloth.
2. Mild cleaning: Use warm water with a little dish soap. Use a soft, damp cloth (never soaking wet).
3. Treating stains: For stubborn stains, I recommend toothpaste without gel. Gently rub it in, then wipe off with a damp cloth.
4. Not suitable: Avoid abrasive cleaners, strong chemicals, or acetone-based products – these will damage the finish.
5. Drying: After cleaning, immediately wipe with a dry cloth to prevent moisture marks on the wood.
Important: Test the method on an inconspicuous spot to ensure no discoloration occurs.
I hope this helps. If you have any further questions, feel free to ask!
RENMA
23 Sep 2020 16:27
dijan schrieb:
A mixture of warm water and a little dish soap
This is basically a good approach. However, it should be noted that dish soap can leave residues if not wiped off thoroughly.
TANBLA schrieb:
Vinegar water (1:1 with water)
Although vinegar is a common household remedy, it can damage the seal on Malm fronts. In my experience, it is best to avoid vinegar if you want to maintain the surface over time.
My recommendation:
- For water stains, using a very fine steel wool pad (0000) with some furniture oil can be effective, but this method is only suitable for experienced users.
- As a general cleaning agent, I suggest a mild wood cleaner or specialized furniture care products.
Conclusion: Be cautious with acidic cleaners, and always wipe thoroughly to avoid leaving residues.
SUDAN
24 Sep 2020 10:37
I would like to provide some additional background information:
The IKEA Malm nightstand is made of MDF with a laminated or painted surface, depending on the version. The lamination is sensitive to moisture and chemicals. Therefore, the best approach – as already mentioned – is to use a slightly damp cloth (not soaking wet) and a mild cleaning agent.
A recommended procedure:
- Wipe the stain with a damp microfiber cloth.
- If the stain is stubborn, apply some toothpaste without gel and let it sit for at least 5 minutes, then wipe off with a damp cloth.
- Damage caused by strong cleaning agents should be avoided.
Common mistakes I notice:
- Using too much water.
- Using rough sponges or pads.
- Using acidic cleaning products.
These can damage the protective layer and lead to more stains or unsightly spots.
