ᐅ IKEA Kallax Shows Stains After Several Years – Should I Repaint or Replace It?
Created on: 19 Oct 2023 08:13
Elonfra
I have an IKEA Kallax shelf unit that I bought about 6 years ago. Over time, some unattractive stains have appeared on the surface, apparently caused by moisture and light wear. The shelf is otherwise still stable and functional, but the appearance bothers me more and more.
Now I’m facing a decision: Should I simply buy a new Kallax, or would it be more sensible to sand it down and repaint it?
Does anyone have experience with painting Kallax or similar IKEA furniture? What type of paint would you recommend to ensure the surface not only looks good but also remains durable? And is the effort really worth it compared to buying a new one?
I look forward to your insights and tips!
Good suggestions, thanks!
I really like the idea of painting individual compartments in different colors. This way, I could even further protect the surface while adding a bit more personality.
I’m concerned that without experience in painting, I might create stains or streaks, but with a combination of sanding, priming, and 2-3 coats of paint plus some patience, it should be doable.
Does anyone have experience with painting workshops or courses specifically for furniture painting? Would these be worthwhile for a project like this or not?
Furniture painting courses or workshops can be helpful, especially if you want to become more familiar with the techniques and materials. They usually cover basic rules like sanding, dust removal, priming, and applying multiple layers of paint.
For a single Kallax unit, this is generally not necessary, but if you plan to restore furniture regularly, such courses are recommended.
When painting, pay attention to temperature and humidity, as these factors affect the drying process and ultimately the final result.
Thank you all for the summarized information and ideas. I believe I will proceed with light sanding, priming, and then adding colored accents using a polyurethane coating.
That sounds like a good compromise between effort, durability, and cost.
I will report back on how the project progresses.
