ᐅ How to Prepare the Soil Before Laying Sod to Keep It Weed-Free?
Created on: 23 Aug 2021 19:59
Herr Stein
After completing our new build, quite a bit of weeds have appeared in the garden. On Friday, we are getting 20cm (8 inches) of fresh topsoil, and then we plan to finally sow grass seed. We have cleared the plot of all tall-growing plants. However, I recently found out that the flat, widespread weed remaining is couch grass (quackgrass), which I hadn’t looked into before, especially how difficult it is to get rid of. It’s practically everywhere on the property. Unfortunately, we won’t be able to remove it all by hand.
At the same time, I’m worried that the couch grass will penetrate the 20cm (8 inches) of topsoil and sprout through the newly established lawn.
How would you proceed? We do not want to use herbicides. Is it enough to properly fertilize and mow the lawn regularly, and will the couch grass eventually be suppressed or weakened by constant mowing? Or will I have to remove the couch grass with a weed puller from the lawn repeatedly until it no longer returns? Or am I worrying too much and the couch grass won’t be able to grow through the 20cm (8 inches) of topsoil?
Also, does it make sense to use a rototiller with the fresh topsoil, or not really?
Maybe you have some good advice.
Thank you very much
Herr Stein
driver55
24 Aug 2021 13:16
Herr Stein schrieb:
Maybe you have a good tip.
Mowing, weeding, fertilizing, watering… "until the doctor comes"… and never stop or slack off…
…if a lawn is to become and remain a proper lawn.
BBaumeister
30 Aug 2021 16:04
If you prefer not to use chemicals, there is a gentle method that works well:
- Get a pressure sprayer and vinegar essence (very cheap at any supermarket). Mix 200ml of vinegar essence with 5 liters of water (approximately 7 fl oz with 1.3 gallons) and then thoroughly spray the weeds on a day when no rain is expected. The vinegar breaks down very quickly in the environment. The weeds will die within a short time. Make sure to clean the pressure sprayer carefully afterward, as the vinegar can damage the seals and membranes.
halmi
30 Aug 2021 16:07
In addition, the new soil will contain plenty of weed seeds just waiting to "see the light."
However, right now is actually the best time to establish your lawn, as the "main weed season" is already over. Without constant maintenance, the lawn will turn into more of a meadow week by week, faster than you can imagine.
rick201830 Aug 2021 21:51
With regular mowing, watering, and fertilizing, you can manage most issues. The rest can be handled by hand-pulling or using selective herbicides. A proper lawn requires effort.
Before establishing a new lawn, you can also treat the area with the harsh glyphosate herbicide, though this is usually not necessary.
